lower ball joint again
Old Mar 4, 2012 | 11:44 AM
bmprhmpr's Avatar
bmprhmpr
Default lower ball joint again
Hey all,what is the torque on the top nut ( of lower ball joint ) that holds it to control arm? I know the two side bolts are 25 ft.lbs. and the lower nut to knuckle is 80 ft.lbs. I have GM service manuals and others but can not find upper nut torque specs. Vette is a 1978. Thanks,Frank.
Old Mar 4, 2012 | 01:05 PM
billcarson's Avatar
billcarson
this came with my lowers, and they made the thread, so if you got moog's go with 20 to 30 ft lbs.
Old Mar 5, 2012 | 05:09 PM
bmprhmpr's Avatar
bmprhmpr
Thanks billcarson,I got them in a front end kit from Eckler.( Taiwan on package) Ill go with 20 -30 ft. lbs.
To lower ball joint again
