c3 head room
Old Mar 10, 2012 | 09:08 PM
son of the south's Avatar
son of the south
4th Gear
Default c3 head room
Hi every one this is my first post so take it easy lol so hear go's my buddy has a c4 and it tight on the leg room but I can make do but the head room is just not there "I'm 6'8" how does the c3 compare and is there anything I could do to gain a bit more head room ?
Old Mar 10, 2012 | 09:40 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
I have never been in a C4 without the tops on so I really can't say. But my dad is 6'6" and his head touches the roof of the car when he sits in the C3 I have. Mine are stock seats. I cannot attest to others' custom seat setups or different optioned cars.
Old Mar 10, 2012 | 11:07 PM
73Corvette's Avatar
73Corvette
I'm about 6' 5" most of my height is in my torso, just a 35" length pant...
With seat adjustments as low as I can get them and the seat all the way back against the "wall" I can fit in pretty good...it's the getting in that's a PITA... even getting out isn't too bad.
Old Mar 11, 2012 | 09:29 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I'm 6'8" how does the c3 compare...
Sit in one.
...and is there anything I could do to gain a bit more head room?...
The optional factory glass tops offer a little more headroom over the fibrglass tops because they do not have headliner inserts.
Old Mar 11, 2012 | 09:30 PM
C3 4ME's Avatar
C3 4ME
you can always run fiberglass t tops w/ no headliner. It may not look that great, but will give you a couple of extra inches of head room.
Old Mar 11, 2012 | 11:23 PM
Shark Racer's Avatar
Shark Racer
I have a 78 Pace Car with glass tops, which has pretty much the most headroom of any C3.
It is worse than my 87 coupe was.
My 09 Z06 is better than the 78.
I think my C4 had the most headroom of any vette I've owned.
Old Mar 12, 2012 | 10:15 AM
StingrayLust's Avatar
StingrayLust
I'm 6'4" and I fit in my '71 fairly well. However I did take the liner out as previously suggested. If I hit a good bump I almost hit the fiberglass. Look around on here for other articles as some have gained about 1" by modifying their seat rails.
Of course I tend to drive mine with the top off as much as possible!
As much as I'd love to have a manual gearbox that it came with originally, TH400 now, I'm a fair bit worried about left leg clutch travel. I know some have shortened their turn signal. If I get a 5 speed I may switch mine out for the same one used in the Tilt mechanism.
I also have pretty wide shoulders. It's probably more tight in the shoulder area than headroom. Of course it's just fine with the windows down and the arm hanging out the side.
Old Mar 12, 2012 | 10:37 AM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
I think at 6'8" you'd have to upholster the floor!
Old Mar 12, 2012 | 11:12 AM
rebelee08's Avatar
rebelee08
My son is 6'6" and cannot sit up straight in my 79'. I'm 6'1" and I cannot use the visor because it blocks my view, so I can't forget my sunglasses Glass tops would help a bunch and I'm thinking of getting some, it doesn't help that my headliner panels are shot and hang down more than they should...they got to go! I cannot imagine someone 6'8" driving a vette
Old Mar 12, 2012 | 11:17 AM
son of the south
4th Gear
Thanks for the replays I think I'm gonna put a racing seat in and take the head liner out it doesn't have to win prizes its just gonna be a project I'm thinking about a erod 6.2 backed by a Turbo 350 for the drivetrain
Old Mar 12, 2012 | 11:23 AM
son of the south
4th Gear
Old Mar 12, 2012 | 02:32 PM
Shark Racer
Curious why you'd put a boatload of cash into the motor then skimp on the trans...
Old Mar 12, 2012 | 06:27 PM
son of the south
4th Gear
Didn't think that a well built Turbo 350 was skimping what would you put in it
Old Mar 12, 2012 | 07:12 PM
Shark Racer
Well, I don't see why you'd buy an E-Rod motor (lots of additional expense) and only put a TH350 behind it.
If you're going down that route, a 4L60/65/70E would make more sense, as you can get a transmission controller setup with the E-Rod.
Old Mar 12, 2012 | 07:32 PM
mrvette's Avatar
mrvette
Age 68 here, arthritic suffer for some 25 years or so...
I had a '87 with those side bolsters on the seats and that console that was just flat out toooooo wide, it was getting painful to drive, but height was not a issue....I have a extra vertabre in my lo back so a long torso for a guy who is 6'5"....
and so with my '72 vert, I cut out the rear track mounts and dropped the seat in rear by about 2" cut out the rug/padding in front too....
so the seat has a comfy rake and lowered a good bit now, the pedals and lower firewall were too short for my knees on the wheel, so I cut a wide U shape up to the steering column height, pried it forward, and glassed it into the OEM glass....then bent/cut/welded/modded the pedals to be much closer forward, dropping my knees off the steering wheel, which is a '78+ C3 vette column/wheel dimmer up top where it belongs....
I can get in/out of it really easy, with top up even...another trick is to use the OEM foam with just enough new and remove some springs in the seating, and remove the seat belt cover for more clearance....dropping another 2+ inches down for even more headroom....
I could drive here to California right through without pain, NOW....
Old Mar 12, 2012 | 07:49 PM
scottyp99's Avatar
scottyp99
LOL! This one took me a few seconds to get, but once I got it, it was worth it, I'm glad I hung in there!
Keep the shiny side up!
Scott
Old Mar 13, 2012 | 09:41 AM
Danish Shark's Avatar
Danish Shark
Depends on how worn out the seat foam is
To c3 head room
