how to remove??
Old Mar 14, 2012 | 04:18 PM
optiman's Avatar
optiman
Default how to remove??
Hi All, looking to replace my parking brake cover. 1979 corvette. How do you remove and re install new.
Old Mar 14, 2012 | 04:22 PM
MelWff's Avatar
MelWff
read this link
http://forums.corvetteforum.com/c3-g...r-console.html
Old Mar 14, 2012 | 04:35 PM
optiman's Avatar
optiman
does it just peel up? I see 2 screws in front, how do I get to them? do I remove side carpet on center console, or remove plastice top of center console. I know I should purchase manual. But you guys know everything.
Old Mar 14, 2012 | 08:50 PM
CQRT's Avatar
CQRT
My `73 also has a screw into the back of the console you get to from the center 'cubby' on the back deck - - not sure if 79's have that also . .
Old Mar 15, 2012 | 06:51 AM
optiman's Avatar
optiman
ttt
Old Mar 15, 2012 | 06:54 AM
Redwing01's Avatar
Redwing01
2015 C3 of Year Finalist
Just did it yesterday in my 73 , that hidden bolt accessable through the center rear compartment is a real head scratcher.
Old Mar 15, 2012 | 08:50 AM
Ret.Horsecop13's Avatar
Ret.Horsecop13
St. Jude Donor '11-'12-'13-'14
Get the AIM it will show you everything you need to know about your car. Best 25 bucks you'll spend!
Old Mar 15, 2012 | 09:08 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Redwing01
...that hidden bolt accessable through the center rear compartment is a real head scratcher...
No hidden bolt on the 79s. They have the new style console.
Originally Posted by Ret.Horsecop13
...Get the AIM...
Vinyl ebrake cover clips to the support around the edges of the cover. 77 shown; 79 is the same.
Old Mar 15, 2012 | 10:47 PM
optiman's Avatar
optiman
so I just pull it off and remove 2 screws?, AIM is ordered, should arive shortly. Thanks all
Old Mar 16, 2012 | 04:44 AM
dgood's Avatar
dgood
Remove the two screws. the top (rubber/vinyl piece) has 3-4 loops that hold it to the metal piece. Reach under there and peal them up. You do have to remove the carpet on the sides of the tunnel. It may sound like a pain in the **** but it is actually very easy to do all this if you remove the seats. It is only 4 bolts per seat.
To how to remove??
