Choke cable stiffness
Old Mar 15, 2012 | 06:37 AM
briaineo's Avatar
briaineo
Default Choke cable stiffness
Hi
Is there ya way to lubricate the choke cable?
The one on my 69 is as stiff as can be!
Are they always really stiff?
Old Mar 15, 2012 | 09:35 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
There is no choke cable. Do you mean the throttle cable?
Old Mar 15, 2012 | 11:00 AM
briaineo's Avatar
briaineo
Hey Mike
I did mean the choke cable; located near the base of the steering column!
Very stiff when opening and closing the choke: Maybe i'm using the wrong term. But i'm talking about operating the linkage on the opposite side of the carb to the throttle.
thanks
Old Mar 15, 2012 | 11:49 AM
MelWff's Avatar
MelWff
That's an aftermarket install on probably a Holley. Try some WD-40 or similar spray lubricant.
Old Mar 15, 2012 | 12:41 PM
TimAT's Avatar
TimAT
Check the routing of the cable to make sure it's not got any sharp bends or kinks too
Old Mar 15, 2012 | 01:12 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by briaineo
...Hey Mike, I did mean the choke cable...
Then what you have is not stock.
Old Mar 16, 2012 | 06:03 AM
briaineo's Avatar
briaineo
Well that explains that
Just outta interest how was the choke operated on the original carbs?
Did they have one? Thinking that the electric ones weren't available back then or were they?
Do I actually need a choke anyway; could I just wire it constantly open? would probably forget to open it after warm up anyway!
thanks
Old Mar 16, 2012 | 08:39 AM
stingr4y's Avatar
stingr4y
I too have a manual choke. It worked ok for a few years, but now it sticks and is a pain. Mine has too many tight bends.
You might be able to buy an electric choke depending on the carb, or do like me and just crank it awhile.
Valid question.
Old Mar 16, 2012 | 08:49 AM
briaineo's Avatar
briaineo
Valid question.
Hey stingr4y
Just to let you know Jegs do replacements from 7 bucks
Old Mar 16, 2012 | 09:18 AM
Mike Ward's Avatar
Mike Ward
Electric chokes predate Corvettes by quite a bit, but GM used a mechanical heat-sensitive system for many decades. Cheap, simple, worked perfectly.
Old Mar 16, 2012 | 11:32 AM
Easy Mike's Avatar
Easy Mike
...Just outta interest how was the choke operated on the original carbs?...Did they have one?...
For 69, the choke is intregal with the carburetor on the passenger's side and used a heat stove (thermostatic coil) and rod to open and close. AIM shows the installation.
Later cars had the choke in the same place, but it is electric. The required electrical connnection is part of the engine wiring harness.
No C3s had hand operated chokes.
Old Mar 16, 2012 | 12:07 PM
73Corvette's Avatar
73Corvette
I am not a tech head.... so in simple terms. The Rochester slobber jet carbs have a choke on the passenger side of the carb....it has a spring mechanism that when it gets heated allows a weighted arm to open the choke..... it looks like this on my wifes 73 but I think they are all about the same....
LOTS of these carbs laying around in shops, garages, junk yards....someone one on the forum probably has an old carb....you could get one and redo your choke.
If your carb is an aftermarket Holley or Edelbrock...then I would get an electronic choke at Oriely's or Napa...
Old Mar 16, 2012 | 12:18 PM
MelWff's Avatar
MelWff
based on your previous posts you are running the Summit Racing carburetor 750CFM, mechanical choke. I would contact them to see if they have an electric choke kit available, possbily the Holley version will fit.
Old Mar 16, 2012 | 02:12 PM
Ironcross's Avatar
Ironcross
for what its worth, some 62 Vettes had electric chokes too
Old Mar 16, 2012 | 09:45 PM
TimAT's Avatar
TimAT
Ol' Red hasn't had a choke in ... like forever. Well, since 1971 anyway. Have to play a little footsie until it starts building a little heat, but that's really not an issue and it doesn't take very long.
To Choke cable stiffness
