Identify another wire
Old Mar 15, 2012 | 06:08 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Default Identify another wire
Hello,
While looking around to figure out where a WWF leak was coming from, I discovered this cable no plugged into anything. Any ideas?
Thanks.
Old Mar 15, 2012 | 07:44 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Just going by the location, nothing else, it could be the alarm horn wire.
Kinda under the master cylinder booster on the firewall.
Old Mar 15, 2012 | 08:03 PM
~Stingray's Avatar
~Stingray
Is that something that would be all models? I didn't think the 1980 had an alarm option.
Old Mar 15, 2012 | 08:07 PM
KapsSA's Avatar
KapsSA
Alarm was standard equipment.
Don't see a horn?
Old Mar 15, 2012 | 08:11 PM
~Stingray's Avatar
~Stingray
Don't see a horn?
I will have to re-look when it is light out. I didn't know my year had the option.
I am a complete noob for this...
I guess I was thinking the alarms for these old cars would be like the 70's that have the key lock "alarm on/off" that was by the front wheel fender.
Would I have to set the alarm on my 1980 or does it automatically come on when I lock the doors?
Old Mar 15, 2012 | 08:24 PM
KapsSA's Avatar
KapsSA
If it actually works, turning the driver side key to "lock" sets the alarm.
Not sure about 80s, but 79/78 was a crude system, just the alarm horn, no flashing lights, interlock, or anything special.
81 I think got a little more sophisticated.
The alarm should be lower than the brake booster but over in the fender area. Should be a threaded hole and another wire with an eyelet there if the horn is gone.
Old Mar 15, 2012 | 11:36 PM
vetman1's Avatar
vetman1
He is correct, I was just in that neighborhood on my car this past weekend.
Old Mar 16, 2012 | 11:41 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ~Stingray
...Would I have to set the alarm on my 1980 or does it automatically come on when I lock the doors?...
The owner's manual explains how the alarm system is armed and disarmed. Door key does it when you lock/unlock the doors. Ttops and hood are also included in the alarm.
Spring for an owner's manual. Lots of valuable information in the owner's manual.
Old Mar 16, 2012 | 11:48 AM
briankeery's Avatar
briankeery
Alarm wire....horn must have been continually going off, so they pulled the connector...
To Identify another wire
