Oil temp gauge on 81
Just got the 81 back from the shop. Was having a great day with it when I noticed my Oil temperature gauge bouncing all over the place with each bump. Dumb question time ... can I just replace the gauge with a clock instead? Or am I missing the importance of knowing the oil temp?
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The bouncing is probably due to a bad connection on the sender. Go look at the sender and see if the wire connection is loose. The actual gauge works in a similar fashion to that of a temp gauge. It only requires power, ground and a signal and bounce is usually a loose wire.
If the connection is good at the engine then you should pull the center cluster and check the condition of the printed circuit. Look at the fingers where the connector plugs in and see if one has de-laminated from the board. One may be touching another one and grounding out the gauge.
To answer your clock question, yes.. you can install a clock on the car but you will need to purchase a clock and a printed circuit board.. (or run a hotwire to the clock).
Willcox
Willcox
Former Vendor
You might check the connector on the back of the a gauge too... I forgot this one plugged in separate.
So my shop manual does not show me where the Oil Temperature Sensor is on the engine. It shows me all the sensors down the driver's side of the engine (coolant temp, oil pressure and O2) but no where else. I do know it should be a dark green and white wire.
So where can I find this sensor?
Former Vendor
Hope this helps Tim
IT WORKS AGAIN.
Thanks so much for the help.
The diagram above is correct and the GM 1981 Chevrolet Corvette Shop Manual is incorrect on figure 8A-44. The sending unit was just above the oil filter. As soon as I got under the car I could see that something had hit it from under. The plastic fell apart in my hand but the electrical plug was still good.
Thanks again.
Now on to the next problem of the spare tire for the 81. It's a Goodyear "Temporary Use Only" P195/80D15 Polyspare. Where do I find a replacement? This one is dry rotted.
Thanks again.
Another item needed...
Also needed if replacing the oil temp gauge with a clock is a new gauge bezel. The clock and the oil temp gauge are different with the clock requiring a larger hole, plus a really small hole for the adjustment **** to come through.
Former Vendor
IT WORKS AGAIN.
Thanks again.
Thanks again.
