What is this?
Old Mar 18, 2012 | 10:53 PM
73Corvette's Avatar
73Corvette
Default What is this?
What is the little silver thingy in front of the distributor....looks like it has to do with the vacuum advance.....Our car has the plug, but this part is missing.....what is it?
Old Mar 18, 2012 | 11:00 PM
rogman16's Avatar
rogman16
The AIM says it's an engine solenoid...
Rogman
Old Mar 18, 2012 | 11:04 PM
bigvette1's Avatar
bigvette1
That is the solenoid that routes vacuum to the distributor to advance only when the car is in high gear or when the temp sensor in the block reached I believe 200-210 and you needed advance to cool the engine. Part of the emission equipment for the 73 model year. The wires are to apply 12 volts when one of the two conditions were met.
follow the routing of the vacuum lines from the back base of the carb to the solenoid to the distributor. Probably still works but the question is -- do you want it?
Oh, BTW that is a clean looking block with all in place for the year.
Old Mar 18, 2012 | 11:07 PM
73Corvette's Avatar
73Corvette
Does it have anything to do with opening the solenoid on the hood for the cool air/intake system to work?
Old Mar 18, 2012 | 11:13 PM
73Corvette's Avatar
73Corvette
The pic is actually of oldsarges BB, I needed some help with the EGR and some vacuum line issues...trying to get it all right....but, ours does look pretty good after a little TLC here is a pic
Old Mar 18, 2012 | 11:14 PM
hdpete98's Avatar
hdpete98
It does not control the cowl induction. It is part of emissions control.
To What is this?
