Temporary t-top cover
Old Mar 22, 2012 | 10:11 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Default Temporary t-top cover
Does anybody make a quick detachable cover for T-TOPS. I can take my tops on or off in under 2 minutes but by the time I get them in the bag and in or out of the car its more like 10 minutes. If I drive to work, put them back on, take them off for lunch, put them back on, then off for the ride home, well you get the picture! I would love a cover just to keep dust, pollen or maybe a quick shower out of the car. Corvette Central has a cover but it covers the whole windshield, top and back and costs $185, thats more then my car cover and it does not look quick to install ! Anybody know of a quick , simple cover?
Old Mar 22, 2012 | 10:53 PM
sweeet76's Avatar
sweeet76
dose11 has a targa type top for sale in the parts for sale section. This could possibly solve your problem.
Old Mar 23, 2012 | 06:46 AM
palmbeachvette76's Avatar
palmbeachvette76
Carbrella
http://www.ecklerscorvette.com/corve...1968-1982.html
Old Mar 23, 2012 | 09:46 AM
U17's Avatar
U17
The T-Top brackets are perfect... I had velcro sewn on instead of using the buckle...,
Old Mar 23, 2012 | 10:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Leave the tops on during lunch.
Old Mar 23, 2012 | 10:08 AM
U17's Avatar
U17
You mean they go on also ???!!! I thought you just hauled them around !!!!
Old Mar 23, 2012 | 11:31 AM
81 c3's Avatar
81 c3
Originally Posted by palmbeachvette76
I wonder if the car can be driven with that one installed?
I seen another one on ebay item number 400197554533 that says it is good for highway speeds but is alot more money then this one
cheers
Old Mar 23, 2012 | 12:56 PM
BKarol's Avatar
BKarol
FYI
You need to do some research on how they are attached. The ebay ad actually tells you to use velcro, Ecklers doesn't say, Dose's were latched but more expensive. You place velcro strips on the front and rear of the t-top area. Not bad when the top is on, however you must be able to live with seeing a bunch of velcro strips there when the roof panel is off.
I saw one once and it was not a pretty sight but hey it's your car.
Old Mar 23, 2012 | 02:19 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i have something just like this that i use when i leave the t-tops behind (like on a day when going to a show, etc). it isn't advised to drive with it it is primarily used for a quick on/off if you parked the car somewhere and left it for a short time. i use it should a sudden rain storm happen to protect the interior. if i remember correctly, i did drive home once with it in place (at a reduced speed) and while not perfect it was better than trying to make the trip without anything in the way of covering. it folds up (or more correctly it rolls up) to a pretty small package so it is easy to deal with. the one i have doesn't have any velcro for attachments. it has a foldable "frame" and latches to attach it to the original t-top mounting locations.
Old Mar 23, 2012 | 10:28 PM
BPHORSEGUY's Avatar
BPHORSEGUY
Thanks guys, looks like just what I need!
Old Jan 19, 2013 | 09:28 AM
darrel durand's Avatar
darrel durand
1st Gear
Originally Posted by bphorseguy
thanks guys, looks like just what i need!
how about more info
thanks
To Temporary t-top cover
