Help!!!!
I'm in the process of rebuilding my 79 and have another thread showing progress, but I'm currently stumped by an issue with the rear tires/trailing arms. Here are some pics showing how the trailing arm, hub/wheel/tire are sitting to low. Body is sitting flush on the mounts, so that's not the problem for sure. Anyway, any thoughts on what I've done wrong would be most appreciated.
[IMG]
[/IMG]before the body went on
[IMG]
[/IMG]a view from underside now
[IMG]
[/IMG]Ok, so any ideas/suggestions? Thanks in advance and for looking.
Gary
Also, for some reason, it doesn't look the head of your spring bolt is fully seated, which might also be what is keeping you from tightening the nut enough to insert the cotter pin.
If someone else can confirm this, and if you can take a closer picture of the spring end bolt in its current state, you might be just a few simple steps away from getting the proper ride height.
Other than making sure you've got the bolt set up correctly, I wouldn't be too concerned with it just yet. The rear suspension might settle in with a couple trips around the block.
*edit* If it helps, here is a picture of mine before I took my rear suspension apart:
You can see how the bushing cups sit in the T/A & spring, & can see the flared portion of the cup mounted in the spring.
