Steering wheel
Old Mar 26, 2012 | 03:20 PM
padgett's Avatar
padgett
Default Steering wheel
I noticed my steering wheel is way of center.how much of a job is it to center it.can I just pull the wheel off and make ir rite. Or will it be a pain in the are..it drives me nuts why the poeple had it off in the first place..
Old Mar 26, 2012 | 03:48 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Don't quote me on this because it's been a few years since I've had mine apart. I "believe" the column shaft is cammed to where the steering wheel adapter can only go on one way (and as well the steering wheel bolting to the adapter one way). Maybe the steering shaft/wheel wasn't centered the last time there was an alignment done on your machine. Jim Shea could answer this one for sure. Sorry, not much help. Working off of a 50 year old mind/memory.
Terry
Old Mar 26, 2012 | 03:51 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Take it in for an alignment and have the technician center the wheel as he sets the front alignment. It's a matter of turning the tie rod sleeves to the correct position.
Old Mar 26, 2012 | 04:12 PM
ezobens's Avatar
ezobens
I'm going through this now-
The steering wheel has a scribe mark on the hub, under the big nut that holds the wheel to the shaft.
You need to remove that nut to confirm the steering hub scribe mark lines up with the scribe mark on the shaft that the nut threads on to.
For the life of me, I cannot understand how difficult it is to line those back up if you ever take the wheel off but it happens ALL the time!
I think some Bubbas do that in lieu of getting a proper wheel alignment just to get the wheel to point straight.
Anyway, if the wheel and the shaft marks line up and you're still off (car doesn't drive straight when the wheel is straight), you probably need to get an alignment to get that corrected (tie rod adjustment).
On mine, the scribe marks were about 20 degrees off and my rag joint was also off a notch but I was replacing the box at the time and probably introduced that issue myself.
Elm
Lemans Blue 69's Avatar
Lemans Blue 69
If the alignment is all right, probably should have it checked, the steering wheel can be pulled and slightly rotated to the left or right so it is centered. You will need a steering wheel puller to pull the wheel. The steering wheel locking plate which is under the steering wheel has a spline so it can only go on one way. The steering wheel and post both have a scribe mark on them which can be used as a reference for proper positioning. Some individuals will pound on the post with a hammer while pulling up on the wheel which is something I wouldn't do but when pulling the wheel, always leave the steering wheel nut on a few turns from the top to prevent damage to the post threads.
Old Mar 26, 2012 | 07:22 PM
padgett's Avatar
padgett
Thanks,ill take it in to someone who knows about these things. Hell back in the day we use to yank the wheels off and put those tiny chainlink ones on with no problem cool on a 75 ford,not on a 77 VETTE
Old Mar 26, 2012 | 07:47 PM
Mooser's Avatar
Mooser
I thought those were just so you could drive while wearing hand-cuffs
Mooser
To Steering wheel
