C6 engine in c3 cost????
Old Mar 29, 2012 | 08:48 PM
iandm's Avatar
iandm
Default C6 engine in c3 cost????
Just curious to the cost of the c6 engine conversion in a c3. What would the benifits be over a upgraded 350?
Old Mar 29, 2012 | 08:54 PM
U17's Avatar
U17
I don't know the cost but I would think having to install and set up all the electronics would be expensive unless you can do that yourself...
Old Mar 29, 2012 | 08:57 PM
briankeery's Avatar
briankeery
I would hazard a guess that the guys on this forum doing LS conversions properly are probably on the hook for $10,000 to $15,000 all day long.
Old Mar 29, 2012 | 09:15 PM
Gordonm's Avatar
Gordonm
In the middle of an LS3 in my 72 and yes it is very expensive. There have been some done very inepensivly also. I chose to go the full on route and the time and money is a lot. I also chose not to keep track of how much.
Old Mar 30, 2012 | 02:26 AM
DEEPSEA70's Avatar
DEEPSEA70
Not to mention the engineering and fabrication needed to make it all fit.
Putting in a 2010 Ls3 Grand Sport dry sump into my 70.
lots of fun though.
Old Mar 30, 2012 | 03:24 AM
oldalaskaman's Avatar
oldalaskaman
[QUOTE=Gordonm;1580417411]In the middle of an LS3 in my 72 and yes it is very expensive. There have been some done very inepensivly also. I chose to go the full on route and the time and money is a lot. I --
-------->also chose not to keep track of how much.
good man
Old Mar 30, 2012 | 03:58 AM
Solid LT1's Avatar
Solid LT1
You can put a carb on them and run a $350 MSD coil/ignition timing controller if you don't like digital volt meters and computers (yes the intake is another $300 item.)
Old Mar 30, 2012 | 04:04 PM
jcloving's Avatar
jcloving
From what I have read on this forum, the cost is 10k and up. You could buy two really nice crate motors for that kind of money.
Old Mar 30, 2012 | 06:01 PM
jesse10886's Avatar
jesse10886
Wait extremely patiently for a fleabay or Craigslist used ls motor in the $3-7 k mark depending on mileage ect then another $5k to install properly Problem is the engine swap can be done as a simple an fast (few month) project if you find NOTHING else wrong or that you want to change in/on your vehicle in the process all the little things that are unique to every build is where it comes bak to bite you in the **** an that is possibly another couple thousand
The numbers above are spot on in my opinion but I have never done this mod on this car but have done several v-8 swaps in several other vehicles
Old Apr 1, 2012 | 01:22 AM
Solid LT1's Avatar
Solid LT1
LS3 (3/4 long block) is $4800 at Parts Taxi (forum vendor.) If you want to go "old school" you should be able to have it running for under $8K if your an "glutton for punishment" like myself, you find a dry sump LS3 project and re-cam it and yes expenses can get out of hand
I did just score some truck coil packs/brackets at the wrecking yard for a good deal (the good 585 coils with the heat sinks)
To C6 engine in c3 cost????
