Steering Column Help
Old Apr 2, 2012 | 08:11 PM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
Default Steering Column Help
Can someone shoot me a Exploded view of all parts of the Tilt/ Telescopic Steering column for my 74. the car was stolen and some parts were broken.Need to know what All I need to buy to rebuild it back to specs! Thanks in advance
Old Apr 2, 2012 | 08:26 PM
Lupigiato's Avatar
Lupigiato
Sorry to hear your 74 was stolen. Hope the jerks that are responsible were caught, or karma gets them back 10-fold!!! As for the column, do you have an AIM? Every piece in the assembly is exploded in there
Old Apr 2, 2012 | 09:24 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This may help you some...
http://willcoxcorvette.com/repairand...lp.php?hID=313
http://willcoxcorvette.com/advanced_...ering%20column
Old Apr 3, 2012 | 02:00 PM
redcruz1120
St. Jude Donor '09
Great !!! Thanks for the link!!!
Old Apr 5, 2012 | 02:31 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Well, as long as we're on the subject, I like the write up, but you forgot one teeny-tiny, but oh-so-critical part. Just how the hell do you compress that spring enough to get the assembly (your figure J-1) back in place??? And this is for an '81 with T/T column.
And while we're at it, what is the part and purpose shown in figure F-2?
Old Apr 5, 2012 | 09:23 AM
Jim Shea's Avatar
Jim Shea
You use a allen set screw (in place of the star screw) to keep the upper shaft from telescoping. Then install the compressor tool to compress the spring so that you can install the c-clip. Then remember to remove the set screw and replace it with the star screw. Otherwise you could have a permanently locked telescoping feature.
Jim
Old Apr 5, 2012 | 11:11 AM
IronJen's Avatar
IronJen
Abby Normal
<scratches head>
Maybe I'll have to actually see the tool to know what you're talking about but I'm having a really hard time picturing that. Where would I use an allen screw? On the tool itself?
Oh, also, seriously? The way that thing is put together that spring presses directly on that plastic ring under the column lock plate??? That just seems insane to have that much spring pressure on a piece of 30+ year old plastic. Or am I missing something?
Old Apr 5, 2012 | 01:44 PM
0Willcox Corvette
Former Vendor
If you look at page 5 you'll see the tool and the screw we made for doing this. An allen screw would probably be a better choice as Jim mentioned. We just fab'd up a screw years ago. The tool is in picture H-1 below.
Old Apr 5, 2012 | 03:46 PM
IronJen's Avatar
IronJen
Abby Normal
Yeah, I saw the tool. But how do you attach it to a telescoping column?
Also, am I right that the spring seats directly on that piece of plastic under the column lock plate? That just seems like an insane amount of spring pressure for cheesy plastic.
Old Apr 5, 2012 | 10:55 PM
0Willcox Corvette
Former Vendor
If you go to this link.. it will tell you how to get the tool to work... and it will show you the order in which he items go back together.
http://willcoxcorvette.com/instructi...69_secured.pdf
To Steering Column Help
