Restoring first 'Vette (79)
Old Apr 3, 2012 | 07:29 AM
TRN4L's Avatar
TRN4L
Default Restoring first 'Vette (79)
I'm restoring my very first vette. I've owned a few mustangs but now I see the light lol. Here is some pics of the process. Also I have to say I'm doing this on a shoestring budget!
Right now the motors out for a tear down and rebuild. Installing new Cam & Lifters, A fresh intake, distributor, gaskets everwhere, Plugs/Wires, Etc.
Old Apr 3, 2012 | 09:57 AM
Lupigiato's Avatar
Lupigiato
Good luck with your restoration! Is your project bumper-to-bumper inside and out - body work, paint, interior, etc, in addition to the motor rebuild? Just curious and hoping to follow another start to finish thread
Old Apr 3, 2012 | 10:28 AM
briankeery's Avatar
briankeery
Welcome, looks like you've got your work cut out for yourself. One step at a time....break it down into little jobs; and when you're low on money, or waiting for parts.........CLEAN!!!!!!
Old Apr 3, 2012 | 01:34 PM
TRN4L's Avatar
TRN4L
Thanks guys I need all the luck and advice I can get lol. Yeah its a full project front to back inside and out. So far I've replaced the carpet and done a lot of cleaning up inside. Made sure the motor ran strong. Now I'm doing some performance upgrades and what not. I also have to replace the front calipers as they're leaking at the pistons. I have a 77 donor I have pulled heavy from. Thanks for your intrest!
Old Apr 3, 2012 | 03:50 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: replace all four. Rears are as old as the fronts.
Old Apr 3, 2012 | 03:53 PM
TRN4L's Avatar
TRN4L
Agreed! I already re-did the rears ;-)
Old Apr 3, 2012 | 11:09 PM
TRN4L's Avatar
TRN4L
Tonight I got the engine down to the block and heads. I got as much of the loose paint off as I could. Any suggestions for making sure enough of it is off so the new paint will not flake off? Any other tips and tricks for painting the block/heads is welcomed!
Old Apr 6, 2012 | 09:41 PM
TRN4L's Avatar
TRN4L
Painted the engine today:
Old Apr 6, 2012 | 11:05 PM
briankeery's Avatar
briankeery
Looks good...continued success....
Old Apr 7, 2012 | 10:48 PM
TRN4L's Avatar
TRN4L
Old Apr 15, 2012 | 06:11 PM
TRN4L's Avatar
TRN4L
http://youtu.be/7N9zqI25na0
Old Apr 15, 2012 | 08:29 PM
briankeery's Avatar
briankeery
It's alive....good job
Old Apr 15, 2012 | 11:27 PM
TRN4L's Avatar
TRN4L
Thanks, she sounds aa million times better
Old Apr 16, 2012 | 12:59 AM
jesse10886's Avatar
jesse10886
wow congrats on your first vette good luck on the resto and great choice on the 79! some say 79 is the best year of all c3s!!
Old Apr 16, 2012 | 01:12 AM
AdamMeh's Avatar
AdamMeh
What cam did you use?
Good luck with your project!
Adam
Old Apr 16, 2012 | 09:38 AM
TRN4L's Avatar
TRN4L
I like the 79 cause they put in a glove box lol. Except the previous owner cut it up inside to install a radio
I used simmits K1102 cam
The motor is a L05 from a 93 Chevy pickup soo I have those swirl port heads. I'm gathering parts for an LS1 I have so I won't be chaning these heads.
Old Apr 16, 2012 | 10:44 AM
boeing46's Avatar
boeing46
You have a lot of work to do on a shoe string budget. Good luck and take your time. At 57yrs old I was fortunate to get a car that was well cared for and maintained by previous owners. Have fun.
Old Apr 17, 2012 | 03:02 PM
TRN4L's Avatar
TRN4L
Thanks. I've only got a little further to go before I can dri e her. I'm so excited I can't stand it! She's idling hot, but I'm sampling the temp at the thermostat housing so its not acurate. I'm going to relocate it next time I work on it, but I wonder why she is so hot? Might be this crappy radiator the last owner installed or the mechanical fan isn't right. Idk. Anyone have ideas?
To Restoring first 'Vette (79)
