Newbie question here. Just trying to figure out if I can make my rims shine. I believe they are aluminum and have just oxidized. I know they are originals. I have purchased a can of Mother's aluminum polish. Do I need to just use the 'elbow grease' now? Or will I ever be able to get that mirror finish? When you look at them they almost seem to be painted gray.
Because of the oxidizing I'm guessing your wheels are NOT coated...
That being the case I have had good success using a green scotch guard pad.... wizard polish..... mag polish.....and LOTS of elbow grease....scotch guard first and just go one way, flow with the rim....just go round and round.....it goes scratch them some but you can polish most or all of it back out depending on how picky you are.........
Here is what mine look like and mine were as bad or worse than yours to start with...... I additionally taped off and painted the black......
I apologize......welcome to the forum and great car.... I love that color would look really SWEET with some Black sidepipes...... and powder coat the luggage rack Black also....just sayin
I read in here somewhere that a guy was polishing his wheels.... Car was on stands... He started it and let the rear wheels turn at idle !!! Not a OSHA approved procedure though....
If you want them to really shine you can also sand them with 2000 wet sand paper. That what i did 20 years ago and now i just have to polish them once a year with Mother's aluminum polish.
You want to see so death traps, google something like DIY rim polishing and check out some of the videos' out there. There's a few that make Bubba look like Captain Safety
But in all seriousness, Flitz makes a product called aluminum pre-clean or (something like that) it must be some sort of a very weak acid, spray it on, let sit, scrub, whatever, follow their directions.
It'll do great getting rid of the oxide/gunk/etc prior to starting to polish.
Count on having to touch up the paint in the center and slots
If you want to keep them original, they were a dullish brushed finish. They look good either way. I did mine a little duller than mooser. To bright just did not look right.
I used 1500 followed by 2000 grit wet/dry (WET) then switched over to aluminum polish and finished up with Nevrdull as a final rub. Mine all looked like the one on the right when I started. They had some pretty serious stains on them and the photo below makes them look better than they did in person. Very dull looking when I started.
I work for a trucking company. We use "Fleet Bright" on our wheels. As a pre wash. It has a asid in it. You can get it at some large truck parts houses. It will take the oxedation off. Then buff it out "Metal Bright". Or Mothers Works good. If you want to do it by hand.
Out trucks go off road often as they haul construction equipment. And they can trash the finish on the Aulm quickly. We have 14 costom built Peterbilt. And the owner wants the looking good.
I use Alumapolish [IMG][/IMG]
You can buy it from Alumaclear.com ,its great stuff and the shine lasts a long time.Here in Hawaii I need a product that lasts.
Before:[IMG][/IMG]
After:
If you want them to glow like chrome, you'll have to put some work into polishing them. But, you will probably be amazed at how much better they look if you just rub a little Mother's into them and wipe it off.
If the tires are off you can use myriatic acid and water. Wear glasses and good rubber gloves in a well ventilated area. After that, clean them then polish away.
Once you have them polished you can clean them off with something like rubbing alcohol or ammonia. this will remove any excess polish. When try you can then clear coat them with the spray can stuff that you can get from auto parts suppliers. That will prevent them from getting dirty and keep the shine longer.
Does polished aluminum peel or crack like chrome? I don't think it does but I want to confirm. If you can get aluminum to shine like chrome, but you never have the issue of cracking over time, then why would anyone ever buy a chrome wheel?
It can't peel as it is a cast and machined piece of aluminum alloy unlike chrome which is a multi-layer application of various metals that can crack and chip.
Some people like chrome, some do not. Simply a matter of preference.
