68-70 Gas door hinge spring?
Old Apr 6, 2012 | 02:17 PM
Clams Canino's Avatar
Clams Canino
Default 68-70 Gas door hinge spring?
OK - I think I'm back. (sigh)
I was out for 6+ months after getting run over by a truck.
I'm going to TRY to make forward progress again - LOL
So... I see the vendors sell a 71-82 gas door hinge spring.
My question is:
What do we 68-70 owners do to stop a floppy (when open) door ?
Do we get a spring?
-W
Old Apr 6, 2012 | 05:32 PM
Clams Canino
Hmmmmm. Looks like I'm not off to a rousing start....
-W (shifter console top plate now in - since last post)
Old Apr 6, 2012 | 09:17 PM
7dSHARK's Avatar
7dSHARK
My question is:
Do we get a spring?
-W
Same problem on my 70..Just waiting for a solution.
Old Apr 6, 2012 | 09:53 PM
Clams Canino
Gotcha - OK.
I'm used to holding it up anyway.
I did cut and epoxy a couple of later door bumpers to the bezel to stop any rattle.
That seems to work.
-W
Old Apr 7, 2012 | 09:41 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I'm used to holding it up anyway...
Same here. 68 doors are another of those one-year-only items.
Old Apr 7, 2012 | 10:14 AM
GD70's Avatar
GD70
I use to have a rag handy rolled up to hold the cap open when filling the tank.
Old Apr 7, 2012 | 11:02 AM
54greg's Avatar
54greg
My original 68 door is nice and tight. It stays up when lifted
Old Apr 7, 2012 | 01:09 PM
Easy Mike's Avatar
Easy Mike
You have the only one left which does.
Old Apr 7, 2012 | 01:46 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
My 69 had the same problem. I took the lid off, removed the hing assembly from the car, Put the hinge barrel in the vise and squeezed it just enough to get some friction back on the hinge pin. Stays up great now when I'm gassing up.
Old Apr 7, 2012 | 02:31 PM
gbvette62's Avatar
gbvette62
The 68-70 gas doors don't use a spring, like the 71-82 gas doors do.
On the 68-70 bezel, there is/was a spring steel clip, riveted to the underside of the bezel. When you open the door, the clip is "supposed" clamp on to the the hinge, holding the door open. The problem is, with time and use, the clip weakens and doesn't hold the hinge tight, or breaks off all together.
If the clip is still on your bezel, you can remove the bezel and squeeze the clip a little and it may work again to hold the door open. If the clip is missing, your probably going to need to replace the whole bezel assembly, if you want a properly functioning gas door.
To 68-70 Gas door hinge spring?
