Vacuum headlight questions??
Old Apr 7, 2012 | 04:09 PM
alconk's Avatar
alconk
Default Vacuum headlight questions??
Ok, on my 82 I rebonded the nose brace and finalized everything as far as adjustments ect. I no longer have the vacuum canister but when the car is running and you give it gas the left headlight door starts to pull down. Then in the closed postion the headlight doors are perfectly flushed but as soon as you turn off the car the lights rise maybe a 1/16 of an inch.. Is all this because I don't have a vacuum storage? Or do I have a vacuum relay going bad. I didn't remove any vacuum lines except from the pods.
Old Apr 7, 2012 | 04:29 PM
Mark Riles's Avatar
Mark Riles
You generally lose vacuum at higher engine RPMs. This loss of vacuum affecting the headlights could mean you're missing a check valve or the check valve you have is failing, or that as you suspect you have a relay failing. You can check this by isolating, and testing with a vacuum gun.
Old Apr 7, 2012 | 05:41 PM
alconk's Avatar
alconk
Ok, yea it's only on one headlight . Is there only one check valve back by the distributor on the driver's side??
Old Apr 7, 2012 | 07:24 PM
U17's Avatar
U17
This might help ... http://forums.corvetteforum.com/c3-t...tem-works.html
Old Apr 7, 2012 | 11:19 PM
alconk's Avatar
alconk
Wow, thanks! But that makes it kinda confusing, I don't have a vacumm canister. I can see where it goes (82 it's in the nose) but it's not there??
To Vacuum headlight questions??
