Need an advice
I built a buck to sit the body on which sat inside the rails and on the floor pans. I also put a support across the back to support the cargo area behind the seats and one under the nose to support the front.
Be real careful when you are welding the inserts into the post. The ones at the rear of the door will get the fiberglass very hot and warp if you go to fast. I placed a couple of those freezer ice packs on that area to help remove the heat.
