Mini Starter
Old Apr 15, 2012 | 11:55 AM
javaman's Avatar
javaman
2025 C6 of the Year Finalist - Modified
2021 C6 of the Year Finalist - Modified
Default Mini Starter
Just had a D&B mini starter installed and I am very pleased. Starter definetly spins faster and the best part is that the car starts right up hot. No more praying at gas stations!! Best $57 bucks I've spent in a long time!
Old Apr 15, 2012 | 12:20 PM
Lupigiato's Avatar
Lupigiato
Old Apr 15, 2012 | 06:56 PM
superdave269's Avatar
superdave269
That sounds like a great price. Where did you pick it up from?
Old Apr 15, 2012 | 07:14 PM
mikep3's Avatar
mikep3
I have one for my 78 and have a question.
Did you use the shimms and how did you check for how many to use?
Old Apr 16, 2012 | 07:50 PM
javaman's Avatar
javaman
Google DB Electrical in TN and it should come up.
Old Apr 16, 2012 | 08:04 PM
javaman's Avatar
javaman
Sorry Mike - a question I can't answer. I ordered the starter and had it shipped to the shop that works on my car. I do know that there are two different bolt configurations and what I needed were the staggered bolts. I have a SB and according to my research, it is not hard and fast (with respect to engine) as to what is needed. Did get some very good info when I searched the archives. Hope this helps.
Larry
Old Apr 17, 2012 | 07:16 AM
Ret.Horsecop13's Avatar
Ret.Horsecop13
St. Jude Donor '11-'12-'13-'14
You can get one on eBay free shipping. I put one in about 2 weeks ago. No shims needed went right in and started right up.
Old Dec 19, 2012 | 09:53 PM
rafalc's Avatar
rafalc
Bringing back an old thread but have a question. Just installed one of these starters and Im not sure how to connect the ground cable coming from the frame. Originally it was mounted to the brace which was mounted to the starter and block.
Were you guys able to modify the brace or got a different one if any at all? Also, where does the ground cable connect to now..... the block or one of the front starter terminals?
Old Dec 20, 2012 | 11:09 AM
lvmyvt76's Avatar
lvmyvt76
ground cable usually goes from frame to the engine block.
Old Dec 20, 2012 | 08:49 PM
trw's Avatar
trw
When I put mine in I eliminated the brace (no problems in 2 years) and bolted the ground right to the block.
Love the starter.
Terry
Old Dec 20, 2012 | 09:27 PM
Sidepiper's Avatar
Sidepiper
Do they make these for big blocks? I searched ebay and DB's webste and couldn;t find anything.
Old Dec 20, 2012 | 10:17 PM
rafalc's Avatar
rafalc
http://www.ebay.com/itm/SBC-BBC-CHEV.../130740127035?
says its also for 427 and 454 engines
Old Dec 21, 2012 | 08:31 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
I put one in last winter.
Absolutely the best move I made.
I have a 68 BB.
No shims needed.
I have new battery cables, good grounds,
new battery w/ extra cranking amps.
I did it all and still when it was hot was slow to turn over.
Put the mini in and it turns that 10.25:1 compresion over
like it was a 6 cylinder accord engine
Started right up last summer after shutting it off on 90 plus degree day after idling along at snail speed for several hours in a parade.
No starter brace needed and no heat shield or blankets needed.
Can be used with points ignition too.
Agh technology
Marshal
Old Dec 21, 2012 | 11:50 AM
Matt Gruber's Avatar
Matt Gruber
DB is on the way. my plan is to use a 25#
$50 walmart battery to save weight and $$.
mini's use half the amps to start, so why lug around a heavy battery? normally 35-40#
total 20-25# less weight
Old Dec 22, 2012 | 04:46 PM
thegavel's Avatar
thegavel
I put one on my 74 small block years ago.
No shims BUT did notice that the clutch cover (4 speed)
started to vibrate after I put in the starter, some gentle bending of the cover
sorted that.
Best thing you can do IMO.
Reduces weight, no heat soak probs and
it sounds like a plane spinning up.
Eggnog Cheers,
Gav
Old Dec 22, 2012 | 04:54 PM
C3 4ME's Avatar
C3 4ME
just and FYI for others. I've rebuilt my stock starter and it spins fast enough to register I think 300 rpm. No hot start problems ever, and that is with headers. Mini starters are great, just throwing out another possibility.
Old Dec 26, 2012 | 05:39 PM
Matt Gruber
DB starter arrived. Bench test, solenoid draws 19.5A and works down to 6.2 volts( my 10 amp charger in cardiac arrest)
I've measured the V drop in my 72, and will compare to DB to estimate amps savings, if any.
Also will compare to 5+ year old battery that drops to 9.59v in 10 sec. Can it do 10V?
Old Dec 28, 2012 | 08:51 AM
Matt Gruber
new life for 5 yr old battery! now 10.3v 10 sec crank at 52F.
was 9.59.
draws ~1/3 LESS amps.
so smaller battery is a no-brainer, unless u have hi-amp elec fans and a weak alt.
OLD starter was 24# vs 7.5 mini, so a 16# weight savings, plus will save 10# on my next walmart battery. total savings 26#
Old Dec 29, 2012 | 09:52 AM
fishslayer143's Avatar
fishslayer143
they fit either small or big block with inline bolt pattern
To Mini Starter
