License Plates
Old Apr 19, 2012 | 05:39 PM
superdave269's Avatar
superdave269
Don't know the Texas laws but in Pa. The antique plate is yours forever. One time registartion fee unless you transfer the tag to another antique car. Also no state inspection on antiques, unless you want to drive them at night.
Old Apr 19, 2012 | 11:44 PM
texasbaehr's Avatar
texasbaehr
In Texas the Antique plates dont require an annual inspection. However, I live in Montgomery real close to you, the constables will pull you over if they pass you and don't see the inspection sticker in the windsheild. Some of them know you don't need it and some have to be told. Also the Antique plates have driving restrictions. You are only allowed to drive it to and from shows and events and repairs, parades etc.. It's not really enforced but if a constable or Sheriff sees the car regularly he may stop and warn you.
I use Classic Car plates which are just a specialty plate that DPS charges extra for. The personalized plates are really pricey like $280/yr.
PM me we can get together sometime. I'm near Woodforest.
Old Apr 20, 2012 | 08:38 AM
bashcraft's Avatar
bashcraft
Originally Posted by C3batmobile
But here's the coolest provision: at least the way I read the full law, you can put 'historic reproduction' plates on the car instead of the one they issue.
There are internet vendors that sell these plates for most states. So, you can get any personalized plate 'number' you want - even if it is one that is 'taken' through the regular state system - as long as you get the correct year/version for your state/locality. You then just have to carry your state-provided 'historic car' plate in the car with your registration, etc.
You might want to check on this a little more thoroughly. There's no way they'll let you use the same license number as someone else.
Old Apr 20, 2012 | 02:10 PM
indydoug's Avatar
indydoug
In Indiana, you can display the same number on your car as someone else, because that is not technically your license number. Direct quote from the BMV FAQ page:
What if someone else has the same Year of Manufacture plate number but with a different plate issuance year?
Both customers will be allowed to display the Year of Manufacture plate if the issuing years are different.
http://www.in.gov/bmv/2654.htm
Old Apr 20, 2012 | 02:19 PM
2VettesMike's Avatar
2VettesMike
Originally Posted by ATIS
In North Carolina there are several advantages... the biggest being no more vehicle inspections ($40).
From the other end of NC chiming in here.
You can also run YOM,year of manufacture, plates in NC.
My 72 has on it the 1972 tag the previous owner ran on his Oldsmobile and left it in the basement. Found it when we bought the house and chomped at the bits for another 7 years until that magic 35th birthday rolled around.
The only tricks are you do have to have a regularly registered tag for the car inside to present if requested.
Also the orginal tag you run must be in acceptable condition and not a reproduction or a reconditioned tag.
Luckily at a car show a couple of years ago found a guy that must have had at least 5,000 tags from the 60's through the early 80's. Brand new and in the wax wrappers. NCDMV discarded them.
Now I have one from 1972 used, and three brand new ones....
Great car BTW.
Mike
