Tilt telescoping steering column
Old Apr 20, 2012 | 07:27 AM
edtekk's Avatar
edtekk
Default Tilt telescoping steering column
Looking to buy a rebuilt tilt telescoping steering column for my '73. Who sells a quality rebuilt unit?
Old Apr 20, 2012 | 08:58 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You may try posting this in the Parts for Sale/Wanted section...
If you have an old column, I can rebuild it for you but I don't have any cores to build at the moment.
Old Apr 20, 2012 | 10:51 AM
tjhphoto's Avatar
tjhphoto
Not to hijack the thread but Willcox can you rebuild my column, I collapsed it to get it out and am told it can't be repaired.
Old Apr 20, 2012 | 05:05 PM
Jim Shea's Avatar
Jim Shea
If you just collapsed the steering shaft it most likely can be pulled back out to its original length and safely used.
What year car? If you collapsed the rest of the T&T column you are in big trouble. Steering column jackets and shift tubes are not readily available.
If you can provide the year of the column, I can provide steering shaft lengths.
Jim
Old Apr 20, 2012 | 05:39 PM
tjhphoto's Avatar
tjhphoto
It is a 71 and I just collapsed the shaft that is in the engine compartment.
Old Apr 20, 2012 | 06:38 PM
edtekk's Avatar
edtekk
Anybody hear of or ever use Larry @ Corvette Columns located in Texas?
Old Apr 20, 2012 | 09:24 PM
Jim Shea's Avatar
Jim Shea
The bare steering shaft on your 1971 T&T column should stick out into the engine compartment 4.7 inches from the bearing retainer face. You should pry on the steering shaft to get it back out from inside the steering column. A steady pull is how you want to bring the shaft back out. Do not hammer on the shaft because it could damage the steering shaft bearings.
The steering shaft is actually composed of two shafts that are designed to telescope on each other in a severe frontal collision. The hollow lower steering shaft has a long overlap with the solid upper steering shaft. There are injected plastic pins that hold the two parts to the correct overall length. You have sheared the pins but the parts when pulled back to the correct length will operate very acceptably.
Jim
Old Apr 21, 2012 | 07:32 PM
edtekk's Avatar
edtekk
Thanks for the info on the collapsed column fix. What I'd like to know is who sells a quality tilt, tele unit.
To Tilt telescoping steering column
