body work
Old Apr 20, 2012 | 09:25 PM
tomgaz's Avatar
tomgaz
Default body work
It seems the front of the quarter panel is seperating from the door jam if that is what you call it. What is the best way to repair it. Specifics please.
Old Apr 20, 2012 | 09:31 PM
markids77's Avatar
markids77
There is no repair advice available for the problem as yet shown in your clear, in focus photographs. Said problem will only get worse over time until clear, in focus photographs appear here for all of us to see and appreciate. The panel may eventually fall off of its own accord unless those of us who like to help members who ask questions accompanied by clear in focus photographs can see what the he!! you're talking about.
Old Apr 20, 2012 | 10:55 PM
rogman16's Avatar
rogman16
Old Apr 21, 2012 | 10:08 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Post a pic. That's an appearance area where bonding compound from the joint was supposed to have been smoothed out for seam filling purposes.
Old Apr 23, 2012 | 04:28 AM
tomgaz's Avatar
tomgaz
Default body work
hey mike i sent you a pic of the seam.
Old Apr 24, 2012 | 09:17 AM
Easy Mike's Avatar
Easy Mike
I'm not convinced it's separating, but that is the area I was referencing. That seam was supposed to be smoothed. A little filler might be all you need.
Old Apr 24, 2012 | 09:21 AM
73Corvette's Avatar
73Corvette
Why not send it to Markids77......he's the one that request it?
Old Apr 24, 2012 | 10:55 AM
tomgaz's Avatar
tomgaz
Where it looks black at the lower right is where it seperated.
Old Apr 24, 2012 | 11:12 AM
markids77's Avatar
markids77
That area will need to have the glue cleaned out, and rebonded with a structural adhesive. If the panel releases more as you clean it up you will have to devise a clamping system of some sort to hold the panel in place while the glue dries.
Old Apr 24, 2012 | 11:16 AM
rogman16's Avatar
rogman16
Best fix would be epoxy resin and mat... Next, probably a strong adhesive like MarineTex or Evercoat 870... If it's not separating, filler would be okay as well... Link is to Stinger's thread where he glassed his in (at bottom of the page)...
http://forums.corvetteforum.com/c3-g...ration-67.html
Rogman
Old Apr 24, 2012 | 11:20 AM
Easy Mike's Avatar
Easy Mike
Epoxy. Tape will probably hold it in place while the epoxy sets up. Match it with the trailing edge of the door.
To body work
