What is this wire?
Old Apr 21, 2012 | 02:27 PM
taylorbg's Avatar
taylorbg
Default What is this wire?
It is underneath the driver side of the car. I was under the car today, and it was just hanging there.
Tried to add the images directly to post, but it is not showing up. Here are the links.
https://picasaweb.google.com/lh/phot...eat=directlink
Old Apr 21, 2012 | 02:35 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
LOOKS like the connector for the oil pressure unit. The bell shaped thing above the oil filter.
What year?
Old Apr 21, 2012 | 02:49 PM
Mike Ward's Avatar
Mike Ward
Old Apr 21, 2012 | 04:00 PM
taylorbg's Avatar
taylorbg
It is a 77
Old Apr 21, 2012 | 04:09 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Goes to the switch in the brass block on the top of the driver side frame rail. Activates the brake warning light when there is an imbalance between the front and rear brake systems.
Old Apr 21, 2012 | 04:14 PM
Faster Rat's Avatar
Faster Rat
Old Apr 22, 2012 | 12:12 AM
KapsSA's Avatar
KapsSA
Doesn't the switch on the brake block have a 'stud'?
The connector pic'd goes on a 'spade'.
Old Apr 22, 2012 | 08:42 AM
Faster Rat's Avatar
Faster Rat
You may be right. Mine is a '69, don't know what a '77 has. The brown wire and 90 degree rubber boot looked familiar in that area. If the car has an electric oil pressure gauge...
Old Apr 22, 2012 | 04:34 PM
19LEW71's Avatar
19LEW71
Attaches to the side of the transimission "KICK DOWN at WOT" under driver seat area
Old Apr 23, 2012 | 09:43 AM
taylorbg's Avatar
taylorbg
It looks like it goes to the oil pressure sending unit as per the first suggestion. It didn't fix my oil pressure guage, but it did plug right into the sending unit, and looks like it is a good fit. Next step is to test the sending unit and the wire (there were some splices in it) to see which will fix the oil pressure guage.
Thanks guys.
Old Apr 23, 2012 | 02:07 PM
KapsSA's Avatar
KapsSA
Check the threads on the sending unit. If someone wrapped TOO much teflon tape on them it would affect the ground.
I've read where certain situations will 'spike' the gauge OR cause no movement at all, just don't know which without doing a search.
Old Apr 23, 2012 | 04:41 PM
taylorbg's Avatar
taylorbg
I will just take all the tape off and see what it does. It is pegging out at both ends, just does what it wants. Not sure if it was doing anything before I plugged that wire up Saturday. I was doing other stuff, so didn't mess with it more than plugging it back in. And since the guage did not work before, I never paid much attention to it so I do not know what it was doing before I plugged it back in. I did do some searches Sunday and found some testing suggestions. Maybe this weekend!
Thanks, BT
To What is this wire?
