power brake booster filter question
Old Apr 22, 2012 | 05:35 PM
egates's Avatar
egates
Cruising
Default power brake booster filter question
My 1978 did not have a brake booster filter but apparently is supposed to so I bought one and am installing it. One side is straight, one side is a 90degree elbow. Which is the engine side and which is the booster side? Does it get installed vertically or horizontally - does it matter - I've read that it should be vertical? I've seen pictures with it done both ways. I believe it should be vertical with straight tube downward connected via short hose to metal tube mounted on engine and elbow on top connected to hose that goes to booster.
Old May 13, 2012 | 10:57 AM
egates's Avatar
egates
Cruising
Default so this is what I did...
Here's what I ended up doing. Brakes work so I guess its good...
Old May 13, 2012 | 05:36 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Odd camara angle aside (), it appears to be oriented correctly.
To power brake booster filter question
