Another Electrical Question
Old Apr 23, 2012 | 02:23 PM
Stroh's Avatar
Stroh
Default Another Electrical Question
Before I button up my center shifter console for good AGAIN (I hope), I want to at least identify a couple orphan wires. I do have the 1975 wiring schematic, and have followed it closely, but somewhere along the line some of these wires have been changed out or new ones have been put in.
For instance the brown and white combo is supposed to be for the starter. The starter works fine. In fact I have nothing, aside from my reverse lights, that doesn't function properly unless I'm missing something.
I know it may be impossible for you to ID these from the photos, as I can't figure them out in person, with the schematic. But a shot in the dark is better than no shot at all.
So... Let's play ID that wire. Any ideas guys?
It may be that I don't have to worry about them, because everything seems to work, but I'd hate to close it all back up and have to take everything back out AGAIN to try to trace something down again.
Thanks for taking the time to try to help. I appreciate it.
Old Apr 23, 2012 | 08:07 PM
Stroh's Avatar
Stroh
Yeah... Like I said shot in the dark. That rats nest is no fun. But I guess if it's (almost) all working, why not bury it.
If any body has any clues, especially about the three pink wire connector, that'd help. None are constant power.
If not, thanks again for just taking a look.
Old Apr 23, 2012 | 08:44 PM
Legacy Stables's Avatar
Legacy Stables
OK your first problem is your using the AIM wiring which is known to contain errors. I will pm you with a solution.
Old Apr 24, 2012 | 08:48 AM
71scgc's Avatar
71scgc
Dr. Rebuild o-so-easy diagram should be your next purchase
Old Apr 24, 2012 | 09:51 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
How does it have errors? Does this imply that the assembly workers put it together without consulting the book?
Old Apr 24, 2012 | 12:21 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
They were all men back then - they don't need no stinkin manuals!
To Another Electrical Question
