Factory Paperwork for 1980 Corvette
You could also look for the original Corvette order copy; window sticker; dealer invoice, etc.
Go here: http://www.corvetteactioncenter.com/...x.php?cmd=area and see if you can obtain a copy of the original dealer invoice for your car.
Good luck with the hunt.
You could also look for the original Corvette order copy; window sticker; dealer invoice, etc.QUOTE]
Yeah...that's what I would have writ!
As stated above, the Assembly Instruction Manual (A.I.M.) is a very useful document.
Are you looking for a list of the glove box contents? If so, there was an Owner's Manual, consumer information booklet, tire owners guide & guarantee folder, maintenance folder, vehicle & emissions warranty folder, and an ETR radio manual (if equipped).
If you are looking for the build sheet (tank sticker) then that document, if still there, will be glued to the front of the gas tank. The build sheet lists all the Regular Production Option Codes (RPO Codes) as well as other production information.
A copy of the Dealer Shipping Document is available for 1977 and forward Corvettes from the GM Archives. It lists original dealer, shipping date, RPO codes, etc. - very much the same information as is on the tank sticker.
If you are looking for the Motor Vehicle Manufacturers Association (MVMA) technical specifications for your year car, then they are available as part of the GM Heritage Center package (pdf). That pdf also contains dealer salesman information for your year car. The document (pdf) is available at:
http://www.gmheritagecenter.com/gm-h...tion-kits.html
Click on the link, scroll down the page to "Corvette" and click on "Show". A new page will open that lists the data packages available for various year Corvettes. Select the year - "1980" - in your case. Accept the usage agreement and a pdf will download.
If you can describe more of what your looking for, or how you intend to use the information, you will get a more useful response.
Again, welcome to the Forum.
I have form my 1980 Corvette this Documents:
1. Corvette 1980 Chevrolet Owners Manual. Part Number 14006856 B LITHO in U.S.A.
2. Warranty Information on 1980 Chevrolet New Car Part Number 14021704 LITHO U.S.A.
3. 1980 Chevrolet Consumer Information Corvette Part Number 14006889 C-6
4. GOOD YEAR Limited Warranty Booklet. Part Number 9590439 M2000(7/79) BN
5. 1980 General Motor Maintenance Schedule for Gasoline Fueled Passenger Car Part No. 14006879 A LITHO in U.S.A.
6. build sheet (tank sticker)
you know, it is the Dealer Shipping Document for a 1980 Corvette available?
In a Internet Linkt for 1977 corvette (file:///C:/Users/sascha/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/N9VMN048/C3%20Corvette%20Forum%20-%20Print%20Page.htm)
, I saw that it needs still many more documents.
Thanks you all
sascha
