Fire extinguisher
Old Apr 25, 2012 | 10:13 AM
Mgrad92's Avatar
Mgrad92
Default Fire extinguisher
I'm trying to figure out the best place to mount a fire extinguisher in my 81. Any recomendations?
Old Apr 25, 2012 | 10:18 AM
briankeery's Avatar
briankeery
I keep mine in the passenger side footwell, just in front of the seat. Easy to grab in an emergency, and since it's so far rearward in the footwell, I've never had anyone complain about it interfering with their legs.
Old Apr 25, 2012 | 10:19 AM
Trae1976's Avatar
Trae1976
Same here.
Old Apr 25, 2012 | 10:23 AM
jcloving's Avatar
jcloving
same here:
Remember, it may not be you that grabs that thing to put out your fire. You want it to be visible. I could not afford one of those trick chrome extinguishers.
Old Apr 25, 2012 | 10:24 AM
U17's Avatar
U17
I keep mine on the passenger side wheel hump... not mounted, just laying there... Easy to reach from drivers seat and no fumbling around with latches...
Old Apr 25, 2012 | 10:34 AM
Mgrad92's Avatar
Mgrad92
For those of you who mounted them in the passenger wheel well, did you just screw the mounting bracket to the floor? I'd prefer not to drill any holes in the floor if possible.
It looks like Jcloving used some type of aluminum stock to make a special bracket. How did that work?
Old Apr 25, 2012 | 10:48 AM
Paul L's Avatar
Paul L
The brackets are held down by the seat bolts.
Old Apr 25, 2012 | 10:52 AM
briankeery's Avatar
briankeery
Exactly....thanks Paul, took the words right out of my mouth.
Old Apr 25, 2012 | 11:00 AM
Mgrad92's Avatar
Mgrad92
Who makes that bracket and where can I order one? That's exactly what I need.
Old Apr 25, 2012 | 11:17 AM
briankeery's Avatar
briankeery
http://www.vetteworksonline.com/cata...products_id=77
You can always make one of course......just depends on your wallet.
Old Apr 25, 2012 | 11:20 AM
Paul L's Avatar
Paul L
I can't link to a non-supporting vendor but Google Vetteworks.
It does NOT interfere with operation of the vehicle. You are looking at the 2.5lb Halotron version.
Old Apr 25, 2012 | 11:59 AM
jcloving's Avatar
jcloving
I fabricated mine from 1/8" x 1" aluminum bar stock. It is attachd on top of the seat frame tracks. I plan on painting it dark brown in the next few weeks. The latch is tight but easily opens when pulled.
Old Apr 25, 2012 | 10:30 PM
ATIS's Avatar
ATIS
Does everyone carry a fire extinguisher in their vette? I am new to vettes so is there something I need to know?
Old Apr 25, 2012 | 10:41 PM
briankeery's Avatar
briankeery
Classic car + fire = bad thing
Old Apr 25, 2012 | 10:50 PM
Racer11's Avatar
Racer11
Mine just lays loose behind the pass seat,,,it is bigger than 2.5 so I can't mount it in front of the seat.
Old Apr 25, 2012 | 11:52 PM
AdamMeh's Avatar
AdamMeh
I think I understand what you're asking. It's not that Vettes are a high fire hazard. Old cars are, well... old. It's just smart to protect yourself and if you go to shows, you are protecting others around you as well.
Some of the high end show require all entrants to have an extinguisher in their car. Watching any car burn is horrible, especially one you have worked hard on to make it something you are proud of.
Adam
Old Apr 26, 2012 | 06:22 AM
Mgrad92's Avatar
Mgrad92
Vettes don't have a greater risk of catching fire than other classic cars, but fiberglass will burn, whereas metal won't. So vettes have this nasty tendency to burn hotter, quicker and more completely than other cars. Add that to the 20+ gallon gas tank and that's all the reason I need to carry an extinguisher.
To Fire extinguisher
Old Apr 26, 2012 | 09:57 AM
69 Chevy's Avatar
69 Chevy
A dry chemical fire extinguisher is better than none at all. But the Halotron type clean fire extinguisher leaves no white or pink powder to clean up afterwards. Especially if you nip a small fire in the bud in the engine compartment or interior. Wouldn't matter in the calamitous fire pictured above.
Old Apr 26, 2012 | 11:21 AM
Paul L's Avatar
Paul L
69 Chevy,
What you have shown relates to the fact that fuel pump area from the gas tank is fed by gravity. There is no check valve/shutoff as with a fuel injection system with electric pump. If the rubber "S" holes at the pump are compromised then gallons of fuel can feed the fire. That looks to be the case in that pic. Whe things get to that point a 2.5lb extinguisher is of no use. But it can help to prevent a small carb fire from progressing further. Halotron is also useful for under dash wiring mishaps.
Old Apr 26, 2012 | 10:44 PM
ATIS's Avatar
ATIS
I saw that pict in another thread. I guess its time to be safe and get an extinguisher...and replace my rubber S lines since they are original.
