Steering column problem, somethings loose.
Old Apr 30, 2012 | 09:45 PM
donjack's Avatar
donjack
Default Steering column problem, somethings loose.
My 81 has something in the steering column that is loose from what I assume is people using the steering wheel to assist them in getting out of the car. The wheel does have a little play in it if you lift up on it or when turned quickly (while parked) you can hear what seems to play in the steering column. Any ideas?
Old May 1, 2012 | 09:45 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
If it's a tilt telescopic , there are two screws deep in the colum that need to be tightened , I did a few and I used locktight on them and mine never came loose again.
Old May 1, 2012 | 11:59 AM
VetteNURSE's Avatar
VetteNURSE
Ron, can you elaborate just where these screws are? Mine is doing the same thing.
Old May 1, 2012 | 12:55 PM
73L82AIR's Avatar
73L82AIR
http://http://jimshea.corvettefaq.com/?p=1004try this link
Old May 1, 2012 | 02:57 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Jim Shea will be along before too long.
Old May 1, 2012 | 03:09 PM
jesse10886's Avatar
jesse10886
Does this help?
Old May 1, 2012 | 03:14 PM
jesse10886's Avatar
jesse10886
I was having too much Free travel in my steering. The wheel could go damn near two inches left to right with out effecting the tires. I adjusted the bearing preload and added some grease to my gear box and now she is mucho te solid.
The bolt on the top of gearbox with the flat head cut into it is the preload adjustment
Old May 1, 2012 | 03:20 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
Jesse's pic is good but it does not show the 2 screws, let me see if I can fine a more defined pic, Ron
PM me with an e-mail and I'll send you a better pic
Old May 1, 2012 | 03:24 PM
jesse10886's Avatar
jesse10886
Ron
All threads are worthless with out pics
An you guys can always feel free to tell me that in my own threads if you like lol
I like having a visual to go along with the mechanics in my own head
Old May 2, 2012 | 12:52 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
I agree I did send the PM a pic but can't put it on here or get it to photobucket , maybe donjack can post the pic I sent him. I'm just trying to remember which 2 srcews I tightened. I'm getting old
Old May 2, 2012 | 02:22 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Ron Rail
...If it's a tilt telescopic...
Should be. T/T became standard on the 80 models.
Old May 2, 2012 | 06:07 PM
donjack's Avatar
donjack
Thanks Ron, got the picture on email, that was going to be my next question, which two screws? I can relate to the gettin old and can't rember thing.
Old May 3, 2012 | 07:35 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I'm working on it , the pic is not too good but I'm looking at other pics
To Steering column problem, somethings loose.
