Backup switch help 72 auto
Old May 1, 2012 | 09:09 PM
andycw's Avatar
andycw
Default Backup switch help 72 auto
All,
I recently removed the dash harness and checked every wire for continuity. All were reading correctly so I decided to keep the harness and save a few bucks. However, there is a connection under the center console with a pink and green wire that does not have anything to connect to (picture 1). On the Doc's rebuild diagram, it lists this connection as the backup switch conn. (picture 2). This is an automatic 72. In the AIM, I believe I have found the connection for it but it is taped to the wiring harness (picture 3). Does this mean it wasn't connected? I also do not have any backup lights. What am I missing?
Picture 1
Picture 2
Picture 3
Old May 1, 2012 | 09:37 PM
Peterbuilt's Avatar
Peterbuilt
An automatic has a neutral safety switch which turns on back up lights when the shifter is in "R".
http://www.nrjvette.com/johdotukset/...tte%201972.pdf
Old May 1, 2012 | 10:09 PM
andycw's Avatar
andycw
Default Neutral Safety Switch
Does anyone have a picture of the neutral safety switch for an auto? I did a search and found a post by Easy Mike stating it was located under the center console but this 72 is missing one.
Old May 1, 2012 | 10:20 PM
r66stingray's Avatar
r66stingray
Default back up switch
Andycw
I believe it is the same as a '71 automatic.
I think you would find it under the shift mechanism after removing the top console plate.
From my 71 AIM the wire color codes and the one I removed are the same so it would be a start.
I can send a picture of the one I removed if it helps
It is also listed as a neutral safety/backup light switch in the catalogs.
Steve :thumbs:
Old May 1, 2012 | 10:33 PM
andycw's Avatar
andycw
Default a start
All,
Forgive me. The DARK green/pink wire combo I was looking at in picture 1 is for the seatbelt warning. I do have a neutral safety switch. How can I test it to see if it works properly as my backup lights do not work. I have it hooked up as shown in this picture.
Curious though, and forgive my ignorance, why is the pink wire hooked to the LITE green and the LITE green to the pink?
Steve, Thanks for the help.
Old May 1, 2012 | 11:01 PM
Peterbuilt's Avatar
Peterbuilt
Hi again,
The pink brings 12 volts to the switch and the Lt green brings it to the lights.
Is your NSS new? I heard some new ones have the colors wrong.
Old May 1, 2012 | 11:17 PM
Peterbuilt's Avatar
Peterbuilt
Does this help?
Old May 2, 2012 | 07:58 AM
andycw's Avatar
andycw
Default testing
Thanks Pete, I just need info on how to test the neutral safety switch now to see why my backup lights aren't working
Old May 2, 2012 | 08:17 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If your 72 has AT, it would have had the neutral safety switch. Check the M40 AT option in your AIM. Off the top of my head, the pigtail from the switch plugs into the harness connector you have found.
Old May 2, 2012 | 08:24 AM
andycw's Avatar
andycw
Default Thanks Easy Mike
I found the switch, just ignorance on my part. But, as stated above, why are the wires crossed over when hooked up? Is this correct and how can I test the switch to determine if its defective?
To Backup switch help 72 auto
