Assistance HEI Leads
Old May 4, 2012 | 05:03 AM
Jethrotracey's Avatar
Jethrotracey
Default Assistance HEI Leads
Hey Lad's,
I've bought a HEI distributor for my 69 corvette and want to keep the same look/leads run through covers as original i.e. refer to photo's
I know I'll need to get 90 degree style both end leads, to suit male (spark plug type ends) however has anyone found a kit that is off the shelf that would suit ?
Old May 4, 2012 | 08:19 AM
71scgc's Avatar
71scgc
Make them yourself.
I don't think anyone's pre-made cables are long enough, but don't take that as gospel.
Perhaps order a set and compare lengths??
If you find some, lemme know...
Carter
Old May 4, 2012 | 08:37 AM
oldalaskaman's Avatar
oldalaskaman
big block ?
Old May 4, 2012 | 09:20 AM
KenSny's Avatar
KenSny
If you want the 90-deg ends AND new spark plug wires, try getting a set for a SB 75 or later engine.
What I see in your pictures are the iginition shields and not a HEI distributor. Maybe I'm looking at the wrong area?
Old May 4, 2012 | 05:28 PM
Jethrotracey
Originally Posted by oldalaskaman
big block ?
Sozz forgot to mention, 350
Old May 4, 2012 | 05:30 PM
Jethrotracey
Photo's of motor being removed. Currently rebuilding and will be fitting HEi
Old May 4, 2012 | 05:46 PM
'75's Avatar
'75
Best bet is to get a set of wires for a 75 and get the 75 distributor top shield too.
Old May 4, 2012 | 06:00 PM
Jethrotracey
So did 75 and later have HEI ? and male spark plug type ends on dizzy?
Old May 4, 2012 | 07:12 PM
oldalaskaman
if I remember right they started hei in mid 74 and made it official in 75, some of the big cars had the wires running under the manifolds and may work, my thinking was a big block hei wires. I dont quite remember though, a a small block hei would probably work also. CRS
Old May 4, 2012 | 09:03 PM
oldalaskaman
just went and looked at my 76, same shielding , but with an hei
To Assistance HEI Leads
