What to look for?
I have seen what may be a weak link in the transmission on the 82 and the Cross fire must be a bugger to play with....
Vettes are not cars you can just let set around......they need driven but not abused....if you drive the crap out of it, then you better be a good mechanic and have deep pockets. It looks like many of the corvettes that are for sale have just lead a pretty hard life......driven and not maintained.....left outside to the elements....and then just parked and left for dead. The NICE ones have been babied, garage kept with regular maintance (done right) not bubba.
Sooooo be patient and find a gooooood fixer upper, that needs some cosmetic and TLC, or get ready for the dreaded OFF body resto.....
Regarding the 82, first try your best to ascertain the condition of the underlying metal structure of the body, aka birdcage. That's the area of the car that either destins it for the junkyard or a worthy restoration.
Also, make note of immediate repairs required to make it presentable and safe to drive. Corvettes have many dedicated parts suppliers, a quick check will give you replacement part prices.
The last thing to look at is what the cost of a really nice 82 is currently going for. A quick ck of recent auction prices for nice 82's will give a better indication of current pricing.
Compare your projected purchase cost plus required parts, to what a ready to drive car will cost.
I speak from a little experience as I'm 1/2 way thru a 72 restoration. I'm doing mine exactly how I envision a C3 should look. To outright buy one was more than I had to spend, but paying for the parts as I rebuild each component makes it affordable and I know done right.
There is a "sticky" thread on what to inspect on this era of corvettes. I encourage you to read it then reinspect before purchase.
Starting at about picture 30 you start to see trouble areas.
http://s1052.photobucket.com/albums/s453/oldstylebob/
Even the clown I bought my car from told me it had 88K original miles, but in FL anything older than 20 years reporting the milage is exempt. Opps, minor over sight in his advertising, or done on purpose?
It was very obvious my engine had been redone recently from all the new visible gaskets, parts and paint. But other than the bolts on, I can't tell what was done inside the engine. It wasn't until I got her home and could remove the valve covers did I find the comp-cams roller rockers.
But I looked at plenty of cars that looked stock but supposedly where redone x time again.
I always ask, what does that mean to you. It means different things to different sellers. To some people a new head gasket is a redone motor.
