Fuse Question - 79 Corvette
Old May 12, 2012 | 11:52 AM
elane352's Avatar
elane352
Default Fuse Question - 79 Corvette
Greetings!
Does anyone know which fuse it is within the fuse box that the horns run off of?
I cannot tell from my FSM which one it is.
I installed a high note horn the other day. Neither of the horns are working. So to start the troubleshooting, I wanted to check the fuse first, then the relay.
Let me know please either here or via edwardl301@aol.com
Thanks!
Eddie
Old May 12, 2012 | 12:19 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
There is no fuse for the horn. It runs off the the same circuit as the
lights which uses a fusible link.
Old May 12, 2012 | 06:46 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This will help you..
The 12 volts to the horn relay is a constant and is not fused. It comes off the "hot" side of the panel.
Old May 12, 2012 | 09:26 PM
elane352's Avatar
elane352
Hey Wilcox Corvette,
Thank you so much for the diagram. It is really nice of you to share that information.
Eddie
Old May 12, 2012 | 11:14 PM
0Willcox Corvette
Former Vendor
No Problem Eddie. There are tons of this stuff on the site under the tech pictures section and the Install help and repair section.
To Fuse Question - 79 Corvette
