loose teliscopic
Old May 18, 2012 | 04:06 PM
Hogwild's Avatar
Hogwild
Default loose teliscopic
loose telescopic stearing wheel how can i retighten , stearing wheel was removed not loose before /
thanks
Old May 18, 2012 | 04:24 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
http://jimshea.corvettefaq.com/wp-co...ev13my2010.pdf
Old May 18, 2012 | 05:11 PM
Mooser's Avatar
Mooser
If you mean it won't lock with the ring, pop the horn button off and you can see a screw that locking into one of many grooves on the outside of the center bolt.
Take the screw out, loosen off the lock ring, tighten the center bolt one notch and put the screw back in
Jim's papers (linked above) are extremely good reference for the column
Mooser
Old May 19, 2012 | 12:53 AM
Hogwild's Avatar
Hogwild
thank's guy's
Old May 20, 2012 | 06:14 AM
Roma's Avatar
Roma
Here you find also some good advice
http://forums.corvetteforum.com/c3-g...g-coloumn.html
Old May 20, 2012 | 07:55 AM
Mooser's Avatar
Mooser
Wow, now there is a great thread.
Excellent work to both yourself and Jim. Bookmarked for later referral (hopefully I'll never need it)
To loose teliscopic
