power door windows
Old May 18, 2012 | 05:04 PM
tomgaz's Avatar
tomgaz
Default power door windows
Can someone send me a how to remove the power window from a 77 door. I just bought the sport mirrors and you can't instal them until you remove the windows.
Old May 18, 2012 | 05:56 PM
73Corvette's Avatar
73Corvette
I have a really good idea what it takes..... You will get some GREAT C3 experience with this one...
Old May 18, 2012 | 08:37 PM
dinodon51's Avatar
dinodon51
http://www.mamotorworks.com/corvette...-320-3883.html
Start there and read the tech articles.
You are biting on the tail of a very big dog. I most strongly urge you to take continuous photographs during the disassembly process. Be advised that realigning after you put it back together can require the patience and skill of a zen master. Frankly, I would rather replace a camshaft.
DFS
Old May 18, 2012 | 08:46 PM
tomgaz's Avatar
tomgaz
Well this sucks because I have no patience what so ever.
Old May 18, 2012 | 09:06 PM
Frank_Nesta's Avatar
Frank_Nesta
Patience is what you need. This is a finess (sp) job and I recommend having some one to help you getting out and back in. This site from Wilcox Corvette should help you. Buy now cost $0.00 save it and print it. http://willcoxcorvette.com/advanced_...tment&x=48&y=6. Another little hint is make sure the cable from the mirror to the door is clear of the window. After market mirrors do not have the length as the orignals and may have to be ty-wraped to the door for clearance.
Old May 19, 2012 | 05:17 AM
terry82's Avatar
terry82
on my 82 ,i ran the window up about as far as it could go and took off two bolts.then the window came out.i did not take the window motor or the regulator out .did not have to.
Old May 19, 2012 | 09:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by tomgaz
...Well this sucks because I have no patience what so ever...
BIG learning curve is on the horizon for you. No patience and door glasses do not mix.
Do you have the assembly instruction manual (AIM). It helps and includes instructions for setting the door glasses.
Old May 19, 2012 | 10:54 AM
54greg's Avatar
54greg
This is going to be good
To power door windows
