Alnything else to replace while replacing water pump?
Old May 20, 2012 | 01:25 PM
06MS6's Avatar
06MS6
Default Alnything else to replace while replacing water pump?
Hey guys,
1978 Pace Car 20,043 miles
The water pump started making noise and I noticed it is a bit shaky. the last thing I need is for the fan to disconnect and go right through the hood!
What I'd like to know is, what would you guys recommend me replacing while replacing the water pump? One thing that I thought of is the belts.
Thanks!
Old May 20, 2012 | 01:27 PM
btencate's Avatar
btencate
Fan clutch since its off
Old May 20, 2012 | 01:45 PM
gbvette62's Avatar
gbvette62
I don't know if I would replace a correct original fan clutch, if it was still in working condition, but I would definitely consider replacing the hoses.
Old May 20, 2012 | 02:13 PM
mds3013's Avatar
mds3013
Belts, hoses and thermostat. mike...
Old May 20, 2012 | 02:55 PM
KenSny's Avatar
KenSny
Belts at the very least. And a good time to check all the pulleys for end play and alignment.
Old May 20, 2012 | 09:49 PM
ShootCraps's Avatar
ShootCraps
I always replace the thermostat when replacing a water pump.
Old May 20, 2012 | 10:06 PM
mds3013's Avatar
mds3013
Go through this is you have the time. mike...
http://forums.corvetteforum.com/c3-g...alt-mines.html
Old May 20, 2012 | 10:09 PM
corvette kitty's Avatar
corvette kitty
Originally Posted by 06MS6
Hey guys,
Thanks!
Just did the water pump on my car, along with belts and hoses, heater hoses also. I did replace the the four studs that bolt the fan clutch to the water pump, they were a little worn looking.
Just a thought, if that is the original water pump its dated and you might want to have it rebuilt or hold onto it.
To Alnything else to replace while replacing water pump?
