76 Stingray T-top
Old May 23, 2012 | 10:23 PM
76stingraylover's Avatar
76stingraylover
Default 76 Stingray T-top
Looking at a 76 stingray that has bout a haft to 3/4 inch gap between the windows and the Top. Windows are all the way up. Any ideas why this is happening. Weather stripping doesnt look that bad.
Old May 23, 2012 | 11:01 PM
ShootCraps's Avatar
ShootCraps
Sounds like they may have slipped or just need adjusting. Very easy to do.
Old May 23, 2012 | 11:03 PM
76stingraylover
do you know a good site i could go to read up on how to do that?
Old May 23, 2012 | 11:42 PM
lvmyvt76's Avatar
lvmyvt76
try Willcox corvette parts, or corvette fever,on the web sites, they have a lot of how-to articles. Also the AIM has how-to from the factory specs. It sounds like the top stops are off, you can take the door panel off and look to see if the adjustment has been changed , mark all the bolt locations before changing anything or take pictures to reference to later on when you need to see where it was to begin with. Also Mid-Americ motorworks has a great picture of the door parts break down. If you have a fax, I could fax the pages to you, also the Aim pages. You can them for a catalog @800-500-1500
Old May 24, 2012 | 10:29 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The assembly instruction manual (AIM) has good instructions for setting door glasses along with diagrams. AIMs are good for lots of things.
Old May 24, 2012 | 10:52 AM
76stingraylover
just google AIM manuals?
Old May 24, 2012 | 10:55 AM
CQRT's Avatar
CQRT
You can buy one here for $20 - - good investment:
http://www.ecklerscorvette.com/catal...ssembly+manual
Old May 24, 2012 | 11:33 AM
Easy Mike's Avatar
Easy Mike
Try it. You'll probably get better results with "assembly instruction manual". All the vendors carry the AIMs.
Old May 24, 2012 | 09:15 PM
76stingraylover
thanks i will be gettin one of those manuals very soon, dont want any water gettin in this beautiful car
Old May 24, 2012 | 10:01 PM
Peterbuilt's Avatar
Peterbuilt
Default Too many possibilities...
Could be that the "UP" stops are out of adjustment.
Or the gear is worn out at the top
or some of the rollers are bad
or the regulator is bad
or the weatherstripping is binding, will the window go all the way up if the door is open?
You have to look inside and see whats good or not.
Power windows or crank?
To 76 Stingray T-top
