Gauges to Center Control Console fit
Old May 26, 2012 | 12:30 AM
72and86's Avatar
72and86
Default Gauges to Center Control Console fit
Does anyone know if the the 1977 Gauges Bezel will fit correctly (marry up to) with a 1976 Center Control Console?
I have a 1977 (I think-- see POST, "VIN STUMPER") and inside I have a 77 gauge cluster and a 1976 Center Console. The previous owner for some reason cut out the bottom of the bezel. I have a used Post-1976 bezel I'd like to replace but Im not fit if it will fit up next to it correctly.
Its kinda mess...
(Im can't even be sure the gauges are correct for the bezel/year).
Old May 26, 2012 | 01:04 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
EARLY 77 is the same as a 76 but Late 77 to 82 are the same. The picture is of a Late 77.
Old May 26, 2012 | 08:11 AM
77C34SPD's Avatar
77C34SPD
77 bezel fits 77 only. What you have in your picture are 76 gauges in a 77 bezel that someone broke the bottom side skirts off to wedge into the opening.
To Gauges to Center Control Console fit
