Transmission pan screwed...
Old May 28, 2012 | 05:41 PM
78SilverCam's Avatar
78SilverCam
Default Transmission pan screwed...
Editted - solved my own problem and cant delete the post...
Old May 28, 2012 | 06:10 PM
lvmyvt76's Avatar
lvmyvt76
could this be because of old bolts that need to be replaced? Easy out the broken one, heli-coil the loose one. hand tighten all the new bolts if you can not trust the torque wrench.
Old May 28, 2012 | 06:43 PM
78SilverCam
Thanks for the reply - I editted the page without seeing your response.
And agreed - will just hand tighten the bolts until it feels right/fluid stops leaking...
To Transmission pan screwed...
