1st purchase, what do i ask?
I figured I should ask the community of pros. I'm looking to purchase my first Vette (68-70). I've bought many cars over the years and know what to ask and what sets off the alarm bells.
With a classic car like the vette I really don't know what sort of questions I should be asking. I know I should ask for vehicle history, check to confirm the engine and tranny is original, check allignment of grills to ensure no previous accident repairs.
any other helpful pointers?
It's a frequently asked question and you can either use the "search" function for the forum or simply scroll through the pages to read questions about "what do I look for" or "new Vette owner" . . .I'm not trying to duck your question, just think you can learn an awful lot more quickly if you read through the posts already here.
And if you get serious about one, why not put your city in your profile and ask for a forum member to go with you to assess the car - - might cost you a 12 pack, but money well spent.
Good luck-
Good luck-
Depending on what you're going for, I'd look for originality as much as possible, and buy the nicest car you can afford. I bought a '70 with several aftermarket pieces (intake, carb, headlights) that needed an interior refresh, and it has been a LOT more work and $ than I would have expected to get it fixed and put back to original. There's something about a lower-mileage car that makes a big difference, or one that's gone through a recent restoration (by someone who knows what they're doing!).
Also, be sure to know the differences between the three years. There are many between '68-'70 and it seems like a lot of these parts get mixed up and lost over the years. And replacing them piecemeal on eBay could be a very $$ and time-consuming proposition.
Good luck.
I would ask if the owner minds you taking off the kick plates at the outside foot of the driver and passenger to check where the cage meets the frame / body mounts to check for rust. If there is a lot of rust there, there is likely a lot of rust elsewhere... If that is the case, don't walk... run away.
St. Jude Donor '17, '19
Rust is a big one as a few have mentioned, but it also good to know how it was driven before.
If the PO won't give you specifics, consider the condition of the parts in hidden places and how the interior looks. If things that are not easily visible are not well taken care of, then I would assume that the car itself wasn't carefully cared for. Obviously, take this with a grain of salt as it is still an old car. You have to decide if scratches, worn parts, and an aged interior are because of age or owner neglect.
This is a tough one.. you are talking about a car that is over 40 years old...and most likely more then a few things just do not work... only 4 of my Corvettes have parking brakes that work only 2 of them have radios that work (which is fine with me I dont drive an older Vette to listen to the radio) .. (the cars are all show winners btw) None of them have the heater hooked up so I would assume the heater cores would leak...
Tires may look great but who knows...I presently own 6 Corvettes and replace the tires on one car each spring so I actually have one car that has 6 year old tires on it ..and I may have put up to 12000 miles on those tires...I just do not trust driving on old tires and 6 year old tires are OLD...
I BUY Cosmetics.. I can wrench with the best of them and I found that doing the necessary mechanical work is a lot cheaper then doing the cosmetic work (interiors paint etc)
Bob G.
Bob G.
Rust as others have stated is a huge issue. Often what you see is the tip of the iceberg, VERY expensive to repair, lots of labor involved.
Good luck with your search...
