How to remove ashtray cover on 78 vette
I need to remove my ashtray cover on my 78 so I can repaint it.Can I remove it by just removing the side panle on the consul.Has any one done this
I would say probably not.
The lid is attached by 2 plastic pins, that just push in to place. You may be able to remove them, and later reinstall them.
The problem will be the spring for the lid. I don't think you can remove the spring, with the console in the car.
I've taken a bunch of them apart, but never tried with one, with the console in the car. Hopefully, someone else will chime in, who has tried to do this.
Received 1,469 Likes
Cruise-In II Veteran
GM Cert Corvette Tech
Pro Mechanic
I got mine back IN with just the sides off, but I didn't have the plastic pins mentioned, so I ended up using a pair of small bolts and lock nuts- The tear down wasn't my doing by the way- the PO had all that tore out and packed into a large tote when I got my car.
After you get it painted and back in there, watch the edges of the cover when you flip it open the first time- if it's not centered and squared up just right there's going to be some paint damage and you'll have to do it all over again...
