15 inch wheel question
Old May 31, 2012 | 09:29 AM
crossfire1982's Avatar
crossfire1982
Default 15 inch wheel question
I’ve been considering changing the wheels on my 82 and need input from this knowledgeable group. I know the backspacing on the stock aluminum wheel is 4 inches which would be a -12.00mm offset (according to my chart) but I’m having difficulty finding exactly what Im looking for with a 4 inch backspace. I’m considering the wheels in the link below from Summitt but they are 3.75 inch backspace and an offset of -19.00mm. First of all, will these wheels work on our cars without hitting anything? How will that small difference in backspace affect the geometry of the rear suspension and handling? I am not interested in going with a larger tire than the stock 15 inch. I recently bought new tires and don’t plan on buying a new set for quite a while.
http://www.summitracing.com/parts/SUM-141-5861GM19/
Old May 31, 2012 | 10:40 AM
68-427Rich's Avatar
68-427Rich
Those wheels will not clear the brake caliper. Check out ccw or ps engineering wheels.
Old May 31, 2012 | 06:10 PM
iokepakai's Avatar
iokepakai
Check out this thread.A forum member is using a set of these Legend wheels from Summit..http://forums.corvetteforum.com/c3-g...-5-wheels.html
Old May 31, 2012 | 08:25 PM
crossfire1982
Thanks for your replies guys. iokepakai, the link you posted is exactly what I needed to know, Thanks.
Old Jun 1, 2012 | 09:34 PM
iokepakai's Avatar
iokepakai
Happy to help out....Good Luck.....
To 15 inch wheel question
