Shorts
Old Jun 1, 2012 | 09:13 AM
71scgc's Avatar
71scgc
Dr. Rebuild OSOEASY diagrams. Best ever...
Old Jun 1, 2012 | 10:52 AM
Dose11's Avatar
Dose11
Thanks I will look for this
Old Jun 1, 2012 | 11:12 AM
666WMD's Avatar
666WMD
Reading over your issues I'd say a botched radio install may be causing your other problems too.
I'd recommend taping off all the wires going to your radio and running all new ones. A $20 DMM or a light bulb with wires soldered to it will aid greatly in finding an ignition source (splice the wire from the ignition barrel or run one from the ignition fuse only), and find a decent earth point. Run the power wire direct to the battery (the earth could do the same) and tuck it under the center console until you strip the car in the winter. Don't forget a fuse on both hot wires if the radio doesn't have an onboard one.
Old Jun 1, 2012 | 10:07 PM
Camivette's Avatar
Camivette
papawana on this site will email you the wiring diagram. He has a thread on this forum for wiring diagrams
Old Jun 1, 2012 | 10:22 PM
Dose11's Avatar
Dose11
I'm definitely probably going to redo the radio install....and everything else. Right now it works...let's see if it stays that way.
Old Jun 1, 2012 | 11:40 PM
john roth's Avatar
john roth
QUOTE=71scgc;1580960354]Dr. Rebuild OSOEASY diagrams. Best ever...[/QUOTE]
Old Jun 2, 2012 | 09:03 AM
Ratty68's Avatar
Ratty68
Default Diagrams
Thx again to Papawana!!
Sent me the diagram, now on iPad, open with Kindle, can zoom and everything.
I have a spaghetti nest, lamp cord spliced in, missing lamp connectors, 3.25 amp draw with key off...
Do have electrical background, and will be picking up small fire extinguisher for car and large for garage.
Old Jun 2, 2012 | 09:04 AM
flyeri's Avatar
flyeri
Pull the dash, at least the middle and right side. I found at least a dozen bare wires, several broken ones, and may more spliced wires. Some of the splices did not even have electrical tape on them. I spent about 20 hours just figuring out what had been done and how I wanted to fix it. It was not safe and I am glad i took the time to do it right.
Old Jun 2, 2012 | 09:41 AM
73Corvette's Avatar
73Corvette
Sorry about your issues Dose11...... I think I remember an orange wire while doing my stereo install......I'll see if I can see it without taking anything apart...
Wow, hacking electrical wiring must be an Aphrodisiac for Bubba......it's like he can't stop.
Old Jun 2, 2012 | 05:22 PM
Dose11's Avatar
Dose11
Ehh, it's not too bad...I knew I wasn't buying I perfect car, nor did I pay perfect car money. I knew there would be some issues so I am not really worried. Radio still works tho, problem might be fixed...but we will see. Now come Winter time...we will see what is really going on with the car when I dig into her
