1971 LT1 Valve Seal Question
Old May 31, 2012 | 04:32 PM
Mr Ski's Avatar
Mr Ski
Default 1971 LT1 Valve Seal Question
My LT1 has 70,400 miles and has been burning alot of oil
When the car is hot, and I stepp on it I do see occasional blue smoke - sometimes more then just occasional
My mechanic informed me that the valve seals are brittle, and need to all be replaced
Will this have caused the oil to burn?
With the new seals will I now be okay?
Thank You!!!
Old May 31, 2012 | 05:00 PM
oldalaskaman's Avatar
oldalaskaman
1.yes, have them instsall positive stop seals
2.depending on engine condition ,yes
3.you're very welcome
Old May 31, 2012 | 11:30 PM
mark6669's Avatar
mark6669
Smoke on accel is usually rings, bad valve seals smoke at start up or long periods of idle just my observations over last 45 years of working on corvettes.
Mark
Old Jun 1, 2012 | 01:45 AM
oldalaskaman
mine smoked all the time, positive seal valve seals , 50 years workin' on everythin' , cheapest fix some times works best, nothings absoulute, also qualified it with "depending on engine condition"
Old Jun 1, 2012 | 08:10 AM
Mr Ski's Avatar
Mr Ski
Thank you as always for the quick replies
Buy changing the seals will I get more oil pressure?
Any other effects that I should notice?
To change rings,etc.,does this mean a complete engine job?
How would I know this has to happen?
Would the engine have to come out?
Old Jun 1, 2012 | 09:05 AM
oldalaskaman
1, no
2. yes
3. compression check, bleed down check, if the valve seals dont stop the smoking , you need it
4. yes
Old Jun 1, 2012 | 09:38 AM
oldalaskaman
Mark
this is correct , though, if your car is smoking all the time, time for a rebuild.
Old Jun 1, 2012 | 02:04 PM
24695bob's Avatar
24695bob
Mark
I agree....all of my C3's will soke at start up IF I leave them sit for more then a week.. heck my 76 would smoke if I let it sit more then a day because I replaced the valve seals (with Studebaker-Packard btw) none of the cars used any "noticable" oil at in between my 1000 to 2000 mile oil change intravals..
If you are using oil and see it out the back end when you get into the car with your right foot ..its the rings...
BobG
Old Jun 1, 2012 | 03:55 PM
Mr Ski's Avatar
Mr Ski
Up-date
Valve seals where all brittle and are all now changed
Mechanic thinks that they where the original seals
He did a air test and it shows that all is 100% with no leak
He thinks it should now be okay, but true test will be for me to check the oil and see
I am preying it is all good!!
Thanx again
To 1971 LT1 Valve Seal Question
