I just took out my radiator this morning with the help of my brothers and dad. Did they build the car around the radiator? Holy cow, what a tussle. Now should I get it repaired or buy a new one? It was pretty rough. Good thing we took it out though. The bolt holding the bushings to the a-arm had come loose and the a-arm was coming apart. Now I see how a small repair turns into a frame off.
I'm pretty sure I've seen an old picture of the assembly line and the first things that go are the rad, upper dash pad, center gauge cluster and the parking brake console.
Everything else gets put onto those as it traveled along (don't believe what's written in the AIM, those were only printed to through off the spies from Ford into believing the cars were built differently)
Mooser
Speaking from recent experience, Its best to replace. especially if yours is rough. I just tried to have my 76 repaired and it didnt work. Saving up myself right now to but a new one. I will not say what brand to buy, just buy a quality one. Especially because its a bear to install.
I have the hood off and headlights out so I can paint it and knew it was good insurance to go ahead and pull the radiator and have it tested. Especially since it was covered in leaves and pine needles. Shop said it had too many leaks to repair and would have to be re-cored. It was a replacement radiator so that would be a waste of $$$. Ordered a new one from JC Whitney for $227.
Now I'm wondering if I should replace the heater core. Aaagh, I hate the "while I'm in here syndrome"!!!!
I pulled my Rad and had it repaired. I almost fainted when I got the bill. Now Ihave an old rad and I "could've" had a much more efficient new one for a less.
Reason: reworded
Yeah, I think they wanted $400 to re-core mine. I'm in the wrong line of work.
C3 of Year Winner (appearance mods) 2019
YIKES! I had no idea it cost that much to repair one! If you are not worried about it being original, then I would definitely look into replacing it with something better and be done with it.
There is apuddle of green under my car .... better not be
I paid this shop $80 to repair two holes and pressure test. I took it home put it back in and bang another hole. I did buy a jbweld kit, mixed up a wad of it and put it over the hole. Right now there are no leaks. But I am replacing it once I have enough money. Will hold off on my daily driving till then. I will be going aftermarket rad for $240.
I think it would be wiser to replace the radiator with a new unit. If the car has been regularly driven for the last 35 yrs it is unlikely that it still retains the original radiator it left the factory with. And if you have looked into the cost of recoring a radiator these days, how much money are you really saving?
I feel that the only time I would repair the original is if I was building my car to be ncrs judged. And if I knew it was an original equipment radiator.
If you are planning on building a high performance engine, you will want a radiator with higher efficiency anyway.
I'll be using a DeWitts myself. I installed 1 in my 92 and it is a well made unit that dropped in. I would expect no less for my 72. I know there are others on the market, but I like to support USA manufacturers when I can.
