tire size
Old Jun 3, 2012 | 02:00 AM
rzkas's Avatar
rzkas
Default tire size
hi? what is the best tire to put on a 82 corvette not lowered to decrease the wheel/fender gap. i was told these numbers 295/50/15 and 255/60/15
what do you say?. i want to fill my wheel/fender gap by putting in bigger tire but maintain control and stability and comfort and keeping the stock rally 15" rims
thanks
Old Jun 3, 2012 | 08:49 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Considering that the ability of a tire to perform well, is somewhat dependent on the width of the rim it's mounted on, I personally feel that the 295/50 is too wide a tire for an 8" rim. Consider that GM originally mounted 225/70s, much narrower tires, on an 8" rim. That pulled the sidewalls out a bit, which gave stability to the tread, and allowed for good handling.
A 295/50, on the other had, curls the sidewalls inward, de-stabilizing them, and I'm pretty sure that the handling will suffer accordingly. Yes, they might look "sorta' cool", but they won't work all that well...
Old Jun 3, 2012 | 10:02 AM
CQRT's Avatar
CQRT
I'd say 255-60 . . but if you use the forum's search feature and the tire sizes as key words- you'll get a lot more answers more quickly.
Good luck-
Old Jun 3, 2012 | 10:20 AM
3JsVette's Avatar
3JsVette
The stock size tires are 27" tall. The 255/60-15 is 27" tall. Anything shorter you will need to lower the car accordingly which you made need to do anyway to get "the look" you may be after. The 295/50-15 needs a wider wheel as stated above. Now you get into clearence issues with either the trailing arm or fender lip.
Old Jun 3, 2012 | 10:22 AM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Good luck-
Agree
To tire size
