New Shocks
Old Jun 3, 2012 | 05:57 PM
clandestinerendezvou's Avatar
4th Gear
Default New Shocks
Hi. Just joined. Bought an 82 CE 2 weeks ago, and first thing I need to do is replace the power assist cylinder. I'm going to get the kit that includes the valve and hoses. I also want to replace the shocks. Docs that came with the vette do not show replacement of the shocks. Currently has 61.5 K original miles. Tennessee roads are not the best, so am looking for some info on the best shock to handle the bumps to make it easy on the rest of the suspension, as well as giving good support for corners. Ride comfort is secondary to not beating up the suspension, but it would be nice. I would like to keep it all original, but have done a small amount of research and keep getting referred to the Bilstein Sport Shock. Any suggestions? Thanks.
Old Jun 3, 2012 | 10:14 PM
fanmanbd's Avatar
fanmanbd
Bilstein HD might be more of what you are looking for. Do a forum search for threads on the difference between the two.
Old Jun 4, 2012 | 06:13 AM
4th Gear
Thanks. Will check it out. Great looking avatar.
Old Jun 4, 2012 | 08:49 AM
Marlin's Avatar
Marlin
Here is the top 3 shocks most here have/do use...
Monroe = Factory type shock. Soft ride and no adding to handling abilities.
KYB Gas-A-Just = Firmer than the factory and will help it handle better. Good mid level shock.
Bilstein Sports = Very firm and good to use if you have or will go to a mono leaf rear spring.
I think the KYB Gas-A-Just may fit what you want unless you plan on running a mono rear leaf spring. Firmer but still can do ok on pot holes and other road bumps.
Old Jun 4, 2012 | 04:23 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
For a daily driver, stock replacements will be fine. KYBs are a step up. Bilstein's are overkill for a daily driver.
Old Jun 4, 2012 | 04:32 PM
Paul L's Avatar
Paul L
KYBs serve me well for normal cruising.
Old Jun 4, 2012 | 06:46 PM
4th Gear
Very good. Thanks for all the info. Kurt
Old Jun 4, 2012 | 07:02 PM
Clams Canino's Avatar
Clams Canino
Bilstein Sport = Very firm and good to use if you have or will go to a mono leaf rear spring.
Bilstein HD = One step firmer than Bilstein sport.
(IMHO the sports and the KYB's are really close)
Old Jun 4, 2012 | 07:50 PM
alconk's Avatar
alconk
the Bilstein Sports are more firmer than the HD. I just swapped out the HD for the sports because the HD were bouncy. The sports are perfect now.
Old Jun 4, 2012 | 09:44 PM
Mark G's Avatar
Mark G
Hey, I was just wondering if anyone ever put NOS style (older) non-gas shocks on their car that would mimic the ride that the car came with from the factory, then put gas shocks on to see what the difference would be? I remember years ago I used to install oil shocks on another 80's car I have, then one day I went to gas shocks and from that time on I could fee every darn tar strip and minor crack in the road. It was annoying. And they were direct replacement gas shocks. Anyone run original shocks or non-gas charged shocks?
Old Jun 4, 2012 | 09:49 PM
Clams Canino
You're right - I had it backwards.
-W
Old Jun 5, 2012 | 09:11 AM
spikebot 81's Avatar
spikebot 81
I had kyb gas adjust and with the 330lb new fiberglas vbp rear spring the car was just too bouncey in the rear. Went with bilsteins and fixed the problem. I still have a full set of kyb's with aprox 15000 miles on them, make someone a good deal
Old Jun 5, 2012 | 12:22 PM
Marlin's Avatar
Marlin
alconk said what i was. arrgggg
Old Jun 5, 2012 | 01:01 PM
Frankenvette's Avatar
Frankenvette
I installed Bilstein Sports all the way around. About 6 months ago when I ordered from Van Steel they said Bilstein HD shocks were being discontinued.
Old Jun 5, 2012 | 05:52 PM
4th Gear
What about OEM type shocks like the KYB? What about OEM Corvette? Does the gymkhana suspension of the CE make any difference in choice? And then there's the concours question. Does it affect value with aftermarket vs OEM?
To New Shocks
