Oil Disappearing
I don't have any pictures of my setup right now. But before I hooked up the PCV valve after driving awhile the smell of hot oil would drift into the cabin, now it doesn't. I am wondering if I hooked something up wrong.
I hooked up the PCV valve in the passenger side valve cover to the front of my carb. I have an edelbrock carb. The breather is hooked up from the drivers side to the air cleaner.
Thanks,
Jay
I had a set of covers once that someone had just punched a hole and put the pvc in. When it got hot / rev'd it sucked in enough oil that it actually pooled in the intake manifold
Mooser
Thanks,
Jay
OK, enough fooling around, obviously you suspect the PCV system, too. If the car didn't have a PCV system before, and you would smell oil, it could be from a leak, but it could also be from oil misting out from around seals and such, due to crankcase pressure. The PCV system is relieving this pressure, by allowing the pressure to be sucked into the intake manifold, so you are no longer smelling the hot oil smell. But now, oil is disappearing. It's probably being sucked into the intake. Are you sure you are using the correct PCV valve? Have you done a compression test to check for excessive blow-by? Are you getting blue smoke out the tailpipes? Oil burns blue, that will be a tip-off that oil is being pulled into the intake. Check the plugs, are they oil soaked? Mooser has a good point, I have seen the same thing happen with an un-baffled PCV valve. Good luck!
Keep the shiny side up!
Scott
