Radiator help
Old Jun 5, 2012 | 06:52 AM
chillipepper's Avatar
chillipepper
Default Radiator help
Hi all I wanted to upgrade the cooling system in my 71 so I bought a Stewart's hi volume water pump thermostat and thermostat housing. I also purchased a Dewitt's radiator ecklers part number 54983. I now have a problem the 71 base engine had no expansion tank just overflow pipe this new radiation needs an expansion tank. As I live in Ireland and waited 4 weeks for delivery I don't want to go through the returns procedure etc. it also has the two pins on the base which is a different fitment. Is there anything I can do ie fit an expansion tank or should I just return the item?
Old Jun 5, 2012 | 11:48 AM
chillipepper
Is it possible to retrofit an expansion tank when the car never had one?
Old Jun 5, 2012 | 01:38 PM
Jedi926's Avatar
Jedi926
I recently saw a Nalgene (heavy duty h2o water bottle used for hiking) bottle used as an overflow. Ran the rubber hose from radiator to the bottle top. Screw on top use some teflon tape on the threads, drill hole in top of cap, put hose in (drill the hole just a little smaller than the hose diameter) machine a bracket for the bottle or use zip ties to mount bottle. This will at least keep you going until you figure something more permanent.
OK guys, I know total Bubba right? It actually fit well with the car. I talked to the owner and he now uses items around the house to add his personal touch. He's no Bubba I promise.
To Radiator help
