How can I tell if my door is misaligned. On the passenger side I really have to slam the door to get it to close but not on the drivers side. I put on weatherstripping a while ago and still have to slam it. I think it might be misaligned. All help is appreciated!
The doors on my 71 were hard to close when I first got the car, had to slam them. I put on new seals, adjusted the windows and they now work as they should .
Before you do anything check the door hinge bushings as well. The worst thing you can do is to start adjusting things without knowing what is actually causing the problem.
