Where to purchase complete interior
Old Jun 10, 2012 | 03:15 PM
Dose11's Avatar
Dose11
Default Where to purchase complete interior
Is there a vendor that sells complete interior trim panels as a package? Or do you have to piece together every part?
Old Jun 10, 2012 | 03:26 PM
Indiancreek's Avatar
Indiancreek
I got the carpet, seats and door panels from Willcox a while back (still haven't put them in) They helped with making sure all things matched. You might try there. They all seem to offer the package though.
Old Jun 10, 2012 | 03:38 PM
Dose11's Avatar
Dose11
Yeah I saw that package...but I can't seem to find a trim package. I need every interior trim panel
Old Jun 10, 2012 | 05:26 PM
Indiancreek
If you'd call any of them I suspect they would help you work up a package. I have in the past with Willcox. I feel sure he'd work with you.
Old Jun 10, 2012 | 05:47 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
They're a great company to deal with.
Les
Old Jun 10, 2012 | 05:52 PM
AdamMeh's Avatar
AdamMeh
Are you missing the pieces Dose, or have them and don't want to go the dye route? Just curious as I'm sort of following along on your car because we'll be doing the same basic thing.
Adam
Old Jun 10, 2012 | 07:02 PM
CQRT's Avatar
CQRT
Why not call a few and ask? I'm sure Willcox and others would be willing to put togther a package price.
Old Jun 10, 2012 | 08:06 PM
oldsarge's Avatar
oldsarge
If you are purchasing an entire interior like it sounds, you should be able to get a fair discount putting additional pieces to the offered package deal.
Old Jun 10, 2012 | 09:16 PM
markids77's Avatar
markids77
Original parts fit best and should be refinished and reused if at all possible. Post up some detail pics of your interior; perhaps a fresh finish might be possible on some components. My 77 interior came from at least 5 different cars, and 2 new component vendors but it is coming together quite nicely after some intensive "rattle can" therapy. Rehabbing OE stuff will save you buckets of cash as well!
Old Jun 11, 2012 | 12:43 PM
Dose11's Avatar
Dose11
Sounds Like a plan
Adam
I have them, but majority of them have rips, tears, broken in areas...you wouldn't notice it if you weren't looking. *I have thought about dying some pieces and I still might, but in my mind at least 90% of the pieces need to be replaced *I need to extensively take inventory of all the pieces. *Then I think to myself well...in the future will I have to re-dye the pieces again...and I also would like to make sure all the pieces match...I don't want the dyed pieces to be darker or lighter than the new pieces...so my thought was...Either I can dye everything(but I can't since a lot need to be replaced) or Buy all new pieces....
This is def something I will be doing...
Ahh yes I have heard, and know that original pieces fit best...so now the problem is...how are some repro pieces going to fit with some of the original pieces, when I do it...I wan't to do it right
In my head I kind of think about buying a suite, you go one place find some nice slacks, you go somewhere else you find a nice jacket....you get home...the BLACKS DON'T MATCH....Solution...Buy a whole suite and don't piece it together!
Maybe this is not the case...maybe the dye is right on the money, maybe if I prep and spray right it won't fade a diff color, maybe the repro pieces will fit perfectly next to the OG pieces....there are a lot of maybes in there though.
But can someone tell me...WHY IN THE H*LL rear quater trim panels cost about $300!?!?!?!?! Hopefully those are in decent condition...I don't know if I can justify paying 300 bucks for that piece of plastic!
Old Jun 11, 2012 | 12:58 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: use every stock piece you can possibly use. Clean it, dye it, repair it, restore it, whatever it takes. Nothing reproduction will fit as well as the stock pieces.
Ditto for good used stock pieces. Don't buy if you don't have to.
Old Jun 11, 2012 | 01:21 PM
Dose11's Avatar
Dose11
Alright, so should I try to hunt down used replacement stock pieces and just clean, dye and repair EVERYTHING and not buy any new pieces?
Old Jun 11, 2012 | 01:29 PM
Easy Mike's Avatar
Easy Mike
Up to you. My advice is not to replace anything you do not positively need to replace.
To Where to purchase complete interior
