1969 427/435 info
i HAVE A 69 427/435 THAT I PLAN TO RESTORE. THE VIN IS 195702155 AND THE ENGINE IS TO911LR BODY # IS 194379S702155. CAN ANYONE TELL ME THE OPTIONS AS I AM TOLD IT IS A DELETE CAR ORDERED JUST FOR RACING - M-22 4.11 REAR ETC. SEND INFO TO EDL1@HARGRAY.COM OR CALL ME AT 843 298-9677 THANKS ERIC
Eric-
No information exists on a car by car basis as to which options they came equipped with. If you're lucky, the tank sticker might still be in place which would list the options. Not sure exactly what you mean by a 'delete' car, there was no such thing in 1969. All cars had heaters, wipers, etc. by federal law and could not be deleted by the OEM.
BTW posting in ALL CAPS is considered shouting, kinda rude.
That's the VIN derivitive stamped on the engine, tranny, and frame if they are original.
Tonawanda (NY) engine plant, assembled September 11. LR suffix indicates the 435hp with manual transmission. The M21 was required with this engine, but the M22 was an available option.
If your engine was assembled on September 11, your Corvette has to have been assembled after that date. Check the Time/Build code in the upper right corner of the trim tag.
That's your VIN.
1 Chevrolet Division of General Motors
9 Corvette
4 Half the displacement of the base engine (V8)
37 Body code for a coupe (67 for convertibles)
9 Model year (1969)
S Plant code for St, Louis, Missouri
7 Car line series code. All 69s have this 7.
02155 consecutive unit number
#2155 was assembled in late September, 1968. Jives with an engine assembled on September 11th.
...THE ENGINE IS TO911LR...
...BODY # IS 194379S702155...
9 Corvette
9 Model year (1969)
No build sheet as the tank is long gone. No a/c - no PS or PB it does have a radio - m-22 trans with 4.11 rear end. extra set of iron heads and the original 3x2 setup. 54k original miles - Le Mans blue with black interior. Has the chrome aircleaner and the distrib cover. i appreciate the info
PS and PB were optional in 69, and not near as popular, as they were in later years. Only about half of all 69's had power brakes and about 65% of them had power steering.
I believe the M-22 was only available with the L-88 in 69. The 435 came with either the M-21 close ratio, or the Turbo-Hydro 400. Your trans should have the VIN stamped in the vertical machined service, just forward of where the tailshaft housing bolts up, if it's the original trans.
All 69 Corvettes used a chrome air cleaner lid and all of them that had a radio, used the chrome ignition shielding (distributor cover).
Prior to November 68, all Muncie's were stamped with a "P" on the outside of the case, as part of the date code. After that point, 69 M-22's were marked with a "C" at the end of the date code. The date code is stamped vertically, on the right side lower rear of the case, just forward of where the tail shaft attaches. M-20's were stamped with an "A" suffix, as part of the date code, and M-21's were stamped with a "B".
